MJR said:First on any 96-up XJ or 97-06 TJ if the CPS shorts out internally it will pull the PCM down thereby making the gauges not work, you can't talk to the PCM with a scan tool, and most importantly the fuel pump will not turn on for a few seconds when the key is just turned on to prime the fuel rail.
Special note. Do not just swap engine controllers without knowing one very important thing. You can not swap if one has the factory SKIM (sentry key) or VTSS )theft alarm) and the other does not. As long as both part #'s are the same and both equipped the same (with ot without alarm/sentry key) then it should be safe to test by swapping.
Good piont, dont have to worry about the keyless entry thing on TJ's...
