Hey all, back in the spring I resealed the bottom end when I had at the machine shop. I used Fel Pro gaskets throughout. New timing cover gasket, rear main etc. Sometime in early October after about 10,000 since the work, and just after a 3500 mile trip I saw oil was seating out what looked to be the front center oil pan bolt. There was an oil film about 2" back on the pan from this bolt. I retorqued all the bolts to 84/132 in-lbs. I checked again today and now its all the back to the deep part of the pan. Using a mirror and light I looked all around and don't see any evidence of leakage around the oil pan seal (still nice and blue). I am wondering if I should take the bolt out, smear some RTV on the flange head and see if it helps. Has anyone else had this problem before?
