Before I get into this I've read quite a few threads on here and cannot find one that replicates the problem I am having.
97 xj country 4.0 auto. Wont crank. Starter tests fine by crossing over, but even then it wont run. Tries to fire but acts like its not getting spark. Relays under the hood have been swapped with known working relays. All fuses check out ok. I can't do the relays behind the kick panel though but they are clicking at least. Tried to start in neutral as well. No sound from the starter at all. No power to the solenoid wire when turning the ignition. Can hear the fuel pump running. No security system.....
Whatever it is is keepin the starter from getting the signal on the small solenoid wire and keeping the ignition from firing.
