Ray H
- Falling Waters, WV
Without a CV shaft, the pinion angle should mirror the output shaft angle. If you have -1* on the output shaft, your pinion should be about level (to compensate for a 1 or 2 degree rise under acceleration). Add 4* shims to the rear, not to raise the pinion, but to lower it. The thing with Cherokee leaf springs is that the springs are longer behind the axle than they are in front of the axle, so when you put an arched (lift) spring on, the axle is positioned towards the front of the arch which tends to point the pinion towards the output shaft. If you arent running a CV shaft, you need to shim the axle down to match the output shaft angle. The only reason I mention this is because some people are under the impression that the axle should always be shimmed UP when in fact (I should say "in principal"), to get the ideal angles for a nonCV setup, the pinion should be shimmed DOWN.
Theres a problem with shimming the axle down though. Its DS length and ujoint angle. If you are lifted high and running the stock DS, it probably wont be long enough with the pinion level and your ujoint angles are going to be higher.
