OK but then the argument that a 8.8 is cheaper than a 9' by a drastic amount as stated 2 posts up is TOTALLY false.
I would venture a guess that gears, bearings/install kits and lockers and spools will all be close in price, like wise for the set up and axles. C clip eliminators are prob $150 for a 8.8 and well worth it. So yes a 9" could be built for close to the same price as a 8.8
But the 9 is already strong enough to handle 37s with stock shafts
Nope. The stock carriers are garbage. Seen plenty here go boom on 35's (one on 33's but i think that can be blamed on the driver)you really think that? id run 37's on a stock 8.8 before i ran them on stock 9 shafts....
we break alloy 31 spline 9 shafts regularly....
exactly the route i'm going.I dont know why... But no one has mentioned a 14b FF rear?
With a 200$ shave kit and 100$ ring gear shave, it has beter clearance then Any of the 8.8, D44, 9" etc... It is had for about 150$. Disc conversion total is about 350$. Grizzly locker is about 420$. Gears about 150 and master kit about 100$.
Its stronger then any of the above mentioned. Its very close to the right width 66-67". All you need is to get the 3/4T D44 outer stuff to make your D44 8lug. Then nicer alum 17" rims are even cheaper and easyier to find used then the 5x5.5"
i run 35's on a d44 with all the bells and whistles, and it's been broken 4 times since May. It will only hold up if you're not heavy on the skinny pedal, IMHO.Mostly because he in no way needs a 14b. with a 35-37 max tire size and the trails he runs it would be way overkill. and because it wasn't one of the options he asked about.
Overkill? You mean not able to break it? Cause I know MANY that have spun 8.8 tubes, bent d44 housings, broke f9 28 and 31sp axles, etc... I know he didnt ask about it. But in no way is it not a good option. You are matching width with one, saving $ with one, building it to last for ever with one, and your gaining ground clearance with one.
Just sayin...
