Well i tore into the dash, found the fuse right away, kind of "taped" to the harness about 2" down from the TCU plug.
Fuse was fine? all the wiring looked good and tight.
where is the resistor you were talking about? my power/comfort switch does not work. i have replaced the switch 3 times.
How much would you want for the shift solenoid(s)? I think i am going to start a process of elimination. Junkyard parts are cheap. i'll grab a TCU, a couple of these "resistors" and i'll do a tranny flush. and i'll replace the solenoid(s?) while im at it. this problem has gotten the best of me, i've ignored it for far to long, its making the jeep extremely annoying to drive.
I would replace the fuse anyway, Just to try it, The resistor is wrapped in a tough plastic, its hard to see, but it's between yellow and yellow and blue wires. I have another TCU sitting in my jeep, i grabbed one while i was at the junkyard last time, thinking it would fix my problem. I also ignored, i just shifted it manually, and that got really annoying.
The solenoids are 300 or so on shucks, for whatever reason i don't know why they're so damn expensive.
So i'd say 25 +5 bucks for shipping, does that sound fair?
I can't remember which solenoid is which, 2 of them are the same, and then one of them has a different style of mounting bracket, so i'd just replace them all.
2 of them are a goldish color, and 1 of them is a silver/gray.
2 of them are out of my 96 transmission, the other is out of the 89 transmission, i replaced the OD and 1-2 hoping it would fix my problem.
I can get you a picture if you'd like, or you can PM me.
