5-90
- Hammerspace
Does anybody know where I can find an ax15 from 88-90 xj? Also do the ba10 transfercases direct connect. Do I need and new parts to hook up to the ba10 set up?
You'll need a 23-sp input gear - the BA-10 was 21-sp, the AX-15 (all iterations, that I know of) are 23-sp.
If you can grab the tcase at the same time, do.
Also, check the rearward set of holes for the crossmember in the frame rails - sometimes, the nutserts have rusted out and you'll need to access the inside of the frame rail to use a nut and washer instead.
