BigDawgz
- East CENTRAL INDIANA
$750 United States Dollars....Firm
Located in 47374...Richmond Indiana...
my email is [email protected] and cell is 765 967 4008
1987 Jeep Comanche...4x4...Longbed...4.0 liter...auto...np231...runs good...drives ...4x4 works...will need an eventual left front axle joint...not too bad yet but I heard it squeakin/rattling... It's sat for awhile...so the tranny shifts out too early....sticky solenoids probably but not sure. I just manually shifted the automatic and it made a 16 mile trip to my dad's recently.
4.0
AW4
NP231
D30
D35
31''x10.50''x15'' MudKings on Wrangler type steel wheels...some weatherchecking but all hold air and has usable tread left.
Gas tank drips if you fill it past a certain level...not sure what or where...could be a hose/fitting or the tank...haven't ever even looked at it cause it never leaks cause there's usually only 5 gallons or so in it.
The rearend has already been set up Spring Over...so all that's needed to lift it is front coils to match out the back. It does have 1 leaf in one of the packs that's broken...can't remember which side though.
Will need some patchwork on the floors...rocker panels...and the usual above the bedsides.
Has decent homemade tube bumpers....Factory...LWB Rollbar....interior needs a good cleaning...I've got the instrument cluster apart right now and it comes with a factory tach cluster .....Drivers door window is broken and the rear slider has had one of the panes replaced with plexiglass.
I have a clear Indiana Title for it too.....
You can see where I started the Krylon Camo Ultra Flate Olive Drab Green and Krylon Camo Ultra Flat Black military type paint job...it would look pretty cool finished out like that...and you can get all the paint at wal mart or pretty much anywhere that sells the Krylon Camo line of Ultra Flat paints.
Thanks
Aron
$750 United States Dollars.....Firm
4.0
AW4
NP231
D30
D35
Thanks
Aron
