jeepinandy
- SWVA
another vote for 8's I run 33x12.50 TSL radials have been low as 10psi with no troubles at all :cheers:
kid4lyf said:35-12.50X15 tires.
What size would you recommend for low air pressures?
Fore Wheeler said:can someone explain what a spare is used for??
I think it's for rich kids that need to spend more money.
1toughxj said:So what would be the advantages of the 10" width if any. Stability, footprint width, etc....????
Not last September, he didn't.Paul S said:Brad, don't you run Crawlers? No need for a spare.
Paul
Most likely.jeepjay90 said:so a 36x13.5 swamper would be good on a 15x10?
You still havent changed that? Lazy bastard.OT said:Most likely.
If you have 10" rims, don't worry, just don't air down past 10psi and don't get too nasty.
I would still run 13.5s on 8" rims, before I would buy 10" units.
Hell, I run 35x12.5 on 8"ers at 8psi and burp every one of them, at least, two or three times per day.
This reminds me, I need to replace a valve stem.....
Funny thing about that is, it's torn, almost in half and it leaks, but only when pushed over to one side.
At any higher pressure, it'd probably leak itself down to 8psi.
