flexj
- Manheim Pa
jeep1947 said:Ok, I am on a tight budget but I can see $50 for MORE spring perches. My other concern is the major offset diff. I am stock now, but will be installing a 4.5-5" lift and dont have the money for a sye and ds so will i have a problem with major vibrations because this is a DD. I was wondering if i could just give about 4* more than stock pinion angle to cancel out the vibrations. I also heard the the new ds people get with the sye have more problems with this swap than people with stock ds.
If you are planning on lifting it that much, you should probably wait until you have the $$ for the sye and ds. I've never had problems/vibes with my sye, ds and 8.8 combo. The diff offset is not major, maybe 3". The cv ds more than makes up for that. There are vendors on PBB that have the sye's for less than $200.
