ColoradoRaptor
Headbanging Hillbilly
- Canon City, Crawlorado
Rod Knee said:I think there's another option....alloy shaft 27 spline with Powertrax or lock-right.
Better option!:cheers:
polar_jeep_04 said:does anyone have a link on where to buy the 4140 alloy usa shafts for the 29 spliner? i remeber seeing them for 299 but dont know where
ColoradoRaptor said:You can only get chromoly for full or semi floaters!! The upgrade shafts for the 8.25 a not just replacements, they are about twice as strong as stock! They are not chromoly but the next best thing!
cal said:15% stronger, not twice..
ColoradoRaptor said:I thought it was a bit more than that but it is still better than stock! Thanks Cal!
cal said:Yeah, I'd run them with 35's outside of JV without a second thought.
ColoradoRaptor said:You can only get chromoly for full or semi floaters!! The upgrade shafts for the 8.25 a not just replacements, they are a better alloy and about twice as strong as stock! They are not chromoly but the next best thing! The axel in the 8.25 needs to have some flex to it and chromoly is just to hard!
jaburk said:
Rod Knee said:Yes, that's what I've been looking at for my "96 (27 spline). Seems a bit simpler solution than changing carrier.
FLAGXJ said:Is there a way to tell the spline count without taking the diff cover off and checking inside?
mjma said:Are you positive that you have the 27 spline version?? I thought my 96 had 27 splines, and didn't find out until the 29 spline shafts wouldn't fit into the 27 spline locker-rite...DOH!!
My "96 has a build date in "95. From what I understand, only a relatively small number of the 96's had 29 spline, and they were all built late in that model year production. So, I've assumed I have 27 spline but have actually never checked.
It would be interesting to see your actual production date. It would be on your drivers door jam.
Rod Knee said:It would be interesting to see your actual production date. It would be on your drivers door jam.
jaburk said:
outlander said:Thats what I thought also.Don't know where he got 15% from.One thing I always wondered is if you put in the upgraded 27spline shafts wouldn't that put you into 29spline strength since they are 35% stronger?Plus you get the 10year warranty.
Let me put it this way percent wise how much stronger are stock 29spline shafts compared to stock 27spline?
