NorCalChris
- Central Coast, Ca
Holy Jesus. You are making awesome time on this build. I recommend spin tech mufflers. Very well engineered products. A step above borla, two steps above magnaflow and flow master.
Okay...so I have a dumb question. Were you able to position the motor low enough with the Novak mounts so that you dont have to modify your hood? I believe Frank used the same mounts and the same accessorie brackets, and his alternator hit the hood.
I'm about to do this same swap and I just purchased all LS1 drive accessories to bring the height down. If I can figure out a way around this, I'd resell it and keep the stock vortec stuff instead.
EDIT: I probably should've read the first page. lol
Wondering about the mass air meter being that far away from the TB and what effect it will have on tune as well as fan wash (will it be an issue ?).
I am involved with a LS1 swap on another vehicle and the meter is right in front of the TB. Just asking questions as Im completely ls juan dumb.
Awesome thread! Lots of good info. Keep up the good work.
How is the fit for the 4L80E? Is it tight in the trans tunnel or are they about the same size as a 4L60E?
I bought the cold air kit for a 2010 Chevy 2500 with the 6.0. So it should be dead on. Once I get the radiator in I will install the shield that came with the kit.
Excited to see how the transmission works out... The more pictures you can take the better! The $700 or so that Novak wants is fine if there's nothing else that will do the job. If a $200 model will do it, though...
