33's with 4" lift???
traylor4x4 said:
here is 4 1/4"s on some bald 33's
How the hell did you mount that DirectTV dish on top of your jeep?
TNT said:
That one I couldn't drift, but my '94 it very predictable and easy to control. The low COG makes all the difference in the world...
I have cut XJ fenders so 33x10.5s will fix when fully flexed without any lift or bumpstop work on a stock suspension. It all about the fenders. I make them big enough and still use XJ flares. It's not easy, but its well worth it. 35's fit at 3.5" of lift if done right...
looks like the flare would be in the way when the front wheel is turned
It clears everywhere by 1/2" or more. The tire is about 2" in from the flare in the pic. If it was 3-d you could tell....
lowrange2 said:
Looks like a tail light covered in bedliner with holes drilled in it...
That would be correct.
For those who may be concerned, I'm not using that dinky 2", 7wattish light. I'm using just the lens and the factory bulbs light 'er up. I rewired the back up lights to the brake lights so both lights come on when I hit the brakes.
LEDs will be coming soon.
