can you give us a link as to where to get the double din adapter kit you mentioned using? I wonder if you couldn't do this on an exchange basis, I'm sure you could find plenty of them used at JY etc but I would a much easier project for the DIY guy if he knew it would be done in a few hours and that the worst part is cutting the inside of the hole out.
BUT, I was going to suggest that if you do go into producing them, you might look at fiberglassing them. I don't know much about working with thermoplastics and the blow-molds for them, but you might can do a fiberglass one more easily.
once a mold is made its as simple as pushing a button on a machine. That's why they arent fiberglass from the factory, glass is more durable but is much more involved to produce a high number of.I dont want one since I have older Jeeps and this wont fit my application.
Just a thought.
Very nice work, it looks factory.
You should also consider the TJ market. Their center bezels are similar to ours, and those guys usually have more money than common sense. They'll buy anything - there's no reason why you couldn't make some money off of them.The more I think about this the more I am looking at production options... Stay tuned....
I was just thinking the setup cost would be lower for glass than plastic, and I wouldnt imagine him selling more than a few hundred ever, thats why I suggested it.
you dont happen to have any pics of the top of the jetta kit attached to the factory jeep trim with out any body filler on it do you? i just want to see the lines of it is all. obviously in the finished pics one can see its flat across the top. anyways nice work!
copy that.. just bought the kit. hopefully i dont screw it all up lol. so for the back of the jetta kit, when you fitted it up, you pretty much had to start contourin' it to the xj part? is there alot of material to be removed? when i get it on there, i want it to be pretty much level with the part that is the bottom of the vents (hence it being level up to the vents themselves)? once i get that, then i can trim the opening of the factory peice to fit my deck? sorry for all the questions, but tryin to reverse engineer someones work is more than just slappin the install kit onto the XJ trim LOL. just tryin to see (in my mind) how to approach this.
You’re on the right track!
The Jetta kit itself is not that deep, so depending on how much you want the kit to stick out, will determine how much you shave off the kit. I think mine sticks out past the vents about 1/4 inch but I haven't measured it. I shaved about an 1/8 to a 1/4 off the top and sides. Take your time here you can’t put material back
You will also need to contour the sides down.
Two things I would change with mine
1) Make the top of the Jetta kit the same level as the vent shelf, This will drop the over deck about 1/16 of an inch but give you more headroom above the deck to clear the vent tubes. Mine is very tight here. This also means you will need to cut a portion of the vent shelf back to fit in the top of the Jetta kit opposed to shaving down the kit all the way, you don’t want to shave to much off the kit as on the top as it will degrade the integrity of the kit and possible break.
2) When you fit the Jetta kit, tilt it at about an 87/88 Degree slope, mine is flat and I really have to tilt my screen to see it. I am pretty tall so that has a lot to do with it, but it won’t hurt to do this when you attach the kit as well.
Both of these mean you will need to cut some additional depth into the bottom two side shelves, the ones behind the bezel in the dash, there is plenty of room there.
I worked a little backwards when I first did this. First I cut the back behind the bezel, then cut the bezel then attached the kit and trimmed any excess. All this was to make sure the fitment would work.
If you want to flush the top of the kit to the vent shelf, you will need to cut the bezel at the same time you fit the kit, I would overlay the kit and mark where the bezel needs to be cut, make sure your centered as well. Make your first cuts and test fit. Just be careful not to take too much off the sides where the Bezel adhere to the jetta kit.
^^ this is exactly why I fear tryin this myself.... I have no idea what you are doing as you describe this and I'm sure I would F it up along the way, possibly trashing my trim piece and the radio adapter. And this is why I and I'm sure several other guys would gladly pay $100? for say just the molded in 2DIN trim piece. I'm faily confident I can figure out the areas to cut out the rear of the radio cavity, I know I can do the wiring etc so if I had the ready to use "holder" for the radio it would be a couple hour project at the most.
What kind of filler did you use for conturing?
Lay that thing down flat on the counter, build a box around it, spray it with some sort of non-adhesive spray, then fill the box with silicone caulking compound. Let it set, then flip it over and pull it apart. Now you have a negative that you can cast your positive mold out of. Bondo works pretty well for positive molds if you are careful, bake it in the oven, to cure it, but open all the windows first, it is gonna stink.
Dad used to build his patterns for green sand casting this way.
