fivelitereater
- Indiana
Hello! My Name is John and I'm new to this site. I now own a 2001 Cherokee with a few minor issues. I have been scanning the forum for info and have been able to fix several issues on the XJ. I found and fixed the evap leak, and have fixed the issue with the windows that would only go down from the driver's door panel. All of this was made easier from information in this forum. Thank you all very much!
I need instructions on how to troubleshoot the driver side power door lock circuit. I've already pulled the door panel and have checked the wiring. I have checked the fuse as well. Is there a relay dedicated to each door? Should I be looking for 12v on each side of the connector going to the lock? The lock rod on the door is fine. It doesn't bind or hang up. The other doors work fine.
Any help would be greatly appreciated.
Thanks,
John
Thanks,
John
