- Warsaw, IN
This problem normally happens more when it is cold outside but does happen during the summer as well. Its a 2000 xj with 4.0 in it and when you go to start it up in the morning to let it warm up you have to sit with your foot on the pedal to keep the rpm's up so that it will stay running. Usually it takes a couple of times to get it started as well. Won't start on the first try. Every once in a while i can get it to stay running with my foot off the gas but when i come back outside to leave it has died.
Also i am getting some weird low idle problems. There are days where it will sit and idle in the driveway at around 400-500 rpms. Don't know how it does it but it does.
Need some help with getting this jeep to run a little better. Last winter i went and did a complete tune up on it and put a new tps on it as well as cleaning out the throttle body. Any help would be great.
Thanks,
Ben
Thanks,
Ben
