- Colorado Springs, CO
I have a short in the circuits that originate in the two green wire connector that comes off of the hot post of the starter relay. The short is in the circuit that goes through the dome light fuse. I assumed that the top connector in the fuse block was connected to the hot lead, and this was the connector that went to ground. However, when a new hot lead is run to the bottom fuse connector, no lights, no radio. When run to the grounded(well, less than 10 ohms) top connector the interior lights are on, and the radio works, however the interior lights are NOT effected by the door switches and the radio is switched by the ignition. I've puzzled over the schematics to no avail. I really don't want to have to pull the fuse block out. Working under the dash is not fun when your eyes are bad, along with your back. I think the jeep and I are about the same age in jeep years.
