JWFokker
- Kingston, NY
Cross-posting from JeepForum, but I found this interesting:
Kinda makes me glad I got impatient and ordered a batch of Redline MTL instead of the Amsoil.
440 Magnum said:You can put a hose over the tip of the bottle your gear oil comes in and squeeze it up. Its not too bad.
By the way, DO NOT put the same type of gear oil in the transmission that you put in the differentials. Diffs need hypoid gear oil (API GL5) at least, and limited slip additive if you have a limited slip differential. GL5 and limited slip oils used in a transmission will be "too slippery" (not really, but you an think of it that way- it has to do with the static vs. dynamic coefficient of friction of the fluid) for the synchronizers in the manual trans.
What you need for a manual trans is a fluid with excellent gear lube qualities, but without the friction modifiers for hypoid gears, such as a GL3 or GL4 fluid. They make specialty fluids for manual trannies (Redline MTL or MT-90, for example... Royal Purple also makes them) and these are an excellent choice. Shifting gets *much* better with these fluids, especially if someone has ever allowed GL5 oil to get into the tranny. GL5 won't actually harm the synchros, but can lead to grinding gears since the syncrhos will take longer to do their job as you move the shifter lever.
