MoparManiac
- Amherst, NH
I've seen people notch the cover and weld in a piece cut from some DOM.
I found that rotating the pinion down would help increase clearance but I ended up grinding down the RuffStuff cover.
Damn, now hitting drivers side coil bucket with around 1/4 turn to full lock, and the coil bucket is trimmed back as far as it can be.
Will adjust the stops for now and figure that one out later.
To Vetteboy: Possibly he has adjustable CA, uppers and lowers? I can set my pinion angle with only adj uppers.
Not that easy to bend .25 wall tube. Plus depending on how the drag link is attached to the tie rod, a bend would cause a ton of movement in the steering itself.
My tie rod has bends to help clear the coils and bracketry.
I have a custom 1ton setup(UTK) that has a slight bend in it to clear my diffcover(solid).
Is it a home made deal or similar to the U turn steering or Iron Rock?
Also is it UTK or OTK?
I would love to see picture of it to see how much you had to bend it if possible.
