1 tire straight 1 tire 1/4 outwards
redneckstylin
went wheeling hit some thick clay steering is fubard 1 tire straight other points out .....................
now my trac bar is rubi express the bushing has play and heim has play could that cause this
draglink is off a zj looks good
tierods look good running 1/2 ton dodgers with custom dom tube
but when i turn my steering opposite happens other tire straight and other points out
any opinions would be great
nobody has any input:wierd:
well loosen adjuster nut, adjust the tie rod end so it is right again, re tighten adjuster lock nuts when it is right..
ok i looked at everything
it all looks good except pass side tierod on zj drag link boot is screwed
tire still points out
do you just look at it or did you give it a good shake down. Lift the front off the ground (both sides at once) and check it over good. Was anything loose?
it will not cause one tire to be off like that. it centers the axle under the jeep. It can cause death wobble though. The looseness is not good though.
sounds like you could have pulled a tie rod end out of the threaded piece in the dom tubing.
pics of your steering set up would help though as asked for in the second post otherwise we are all just speculating
