Don't forget to use the Renix flex plate and not the newer one. You also need to look into using the right pilot bearing in the tranny end of the crank if you are running a stick.
X2 this exact issue caused me to be held up on my install for a week. (disclaimer: I only worked on it on Sundays and Wed. nights.) What I found is the 4.2 cranks has steel ring in there instead of a bearing. Slide hammer it untill it's out and tap in the new bearing out of whatever year XJ you are using.
Also do the reasearch on your crank. Some where a little longer and require 1cm to be cut off. You can also get a spacer from Hesco for like 35 bucks. I just used some hardened washers for now. Fits like a glove now.
If you have a Renix motor and use 96+ head, intake, and TB etc, you will have to get the new style speedo cable. About $50 bucks from the stealership. Also the fuel lines to a 96 fuel rail, and an 89 fuel lines don't match up. The clips are different and they are way short. I spliced in some fuel line and just hose clamped onto the fuel rail. No leaks works great.
Also if you us the 96+ TB it was well worth the money for the Hesco adaptor. By the time you get the the point of hooking all that little stuff up you are going to be so excited about hearing it run, that the bolt on adaptor is worth it in my book.
Since you have it out and you have to remove the clutch assembly, save yourself some coin and have them rebuilt. I got mine clutch, and pressure plate rebuilt to a metallic button clutch, and had the flywheel resurfaced for $230 bucks. Way cheaper than Centerforce for a better end result. Love the way it feels now compared to the oem clutch.
Get the quench to .045. Once that number is there it makes alot of other build desisions much easier.
I think the guys name is Oleshot on Jeepstrokers but he will dish the pistons for you for like 75 bucks. Hell of a deal on that.
Though I would give you a few things I ran into on my build. FWIW I just finished my renix 4.6 and couldn't be happier with it. Much easier a swap than a v-8 and just about the same amount of power. If I were to do it again I would have done the 4.7 it was no cost more in machining or parts. When you order the pistons you spec in .030, .040, etc. The machine shop charges you per hole to bore it so no money lost there either.
Parakeet
