foxwar71
- Foxboro, MA
Ive never really liked the cooling setup on my 99 XJ and lately have had some issues of running hot. add to that a dead fan clutch and at least 1/3 of the radiator clogged with mad. since this is now a trail rig only now, i knew i needed something better suited towards low speed driving. i was at a local swap meet and found two 10" elec fans rated at 1000-1200 cfm and 5-7 amp draw. i figure these should take care of the job. i plan to run these as my primary fans and use the factory aux fan (99 style so its the better one) with a switch to have it at factory defualt or constant ON. i figured id add may conversion im doing for anybody thats interested and could use it.
started with pulling the radiator out of the front end
i spent last week doing my new switch panel to control the fans and aux override
i put the top bracketry back on the radiator after i remove it. my plan is to make a shroud that will mount on the top and bottom of the supports so that if needed i can still replace the radiator and make removal possible. this is with the aux fan in stock location
new fans, 1000 cfm 5-7 amp reversiable, they measure 21.5" when next to each other. total width of the core was 31". the factory aux is around 12-13" with the shroud this meant that the fans would have to overhang at the ends by 1-2". the new fans fit fine over the pass side, but the aux fan shroud would interfer with the filler neck, bottom hose, and tranny input/output (auto tranny).
veiw of what needed to be trimmed and such
here is the lower drivers side of the shroud trimmed to fit
i also had to trim a small section of the upper support to clear the top of the aux fan shroud
top side of the shroud trimmed, u can see in the center of the pic where i had to trim the upper support
planned location of the fans (wood is to space the fans away from the core and for mock up of shroud)
i plan to build a shroud out of 18 ga sheetmetal. hopefully i will get started on it tomorrow and have more pics as i update this thread.
