bxj said:Can the Dana 18 or Dana 20 be "flipped over" for driver's side use on the XJ's-TIA
bxj said:Sorry , but I was just dreaming of something like a short NP 241 Rocktrack or a StAK transfer case and was looking for a reasonably inexpensive( read cheap...) replacement in the local boneyards here in the great Midwest for my ageing XJ-Didn't mean no harm by my "newbie question-I just started looking around and found some Ford Bronco 1966 or something Dana 20's-I am needing/wanting something a little shorter and compact but can't afford those prices our " good friends" at the salvage yards are wanting for their Dana 300's-Just curious about those Dana 18 or Dana 20's being able to be "flipped over" to the driver's side for use with the XJ-TIA
Happy New Year !
Jeff 98XJ WI said:I am also considering a Bronco Dana 20 for my MJ. From what I understand, this case is pretty similar to a D300, but is already setup for drivers side drop. It only has a 2.46:1 low range, but if I combine this with a 203 range box then I would get 1:1, 2:1, 2.46:1 and 4.92:1. Since I plan to run a GM 5.3L V8 with a 4L60E auto tranny (which has a 1st gear of 3.06:1) I think the gearing choices would be pretty nice. I do have a bit of a concern over the strength of the case and the cost of adapters to get it all put together, but this is what I am considering. I've also read that the front output shaft can end up being a weak link on the D20 case if you upgrade the rear output to a 32 spline unit...which isn't cheap either. Jeff
xDUMPTRUCKx said:well now im looing into this d20 crap as an alternative to the 231/d300 doubler, it can be twin sticked regeared and is already driverside drop?
whats the desirable years to yank a d20 for this kind of setup?
wow im excited now!
Brian Carpenter said:The d18 is a passenger side drop.. front and rear Not sure about the 20.
Do you have pics of your doubler posted somewhere? I'm interested.
thanks,
bc
bxj said:Happy New Year everyone and thanks for all the input-Today here in the sunny Midwest I back on my merry way down to the local boneyards to see if I can find that Dana 20 transfer case that I had earlier passed up because of my lack of appreciation and knowledge-Good to hear that the ole Dana 20's are still a cost-efficent + durable alternative to those nice Dana 300's-Nothing like these pages here at to enable XJ owners to make a informed decision-Hope no one has picked my Dana 20 up before I get there.
THX again.
Brian Carpenter said:A related Question.. is there a way to run a centered rear diff and an 18? its hard to find offset rear ends that can hold their mustard withour spending a million.
or.. is there a way to give an 18 a center output shaft?
-bc
