Old September 23rd, 2005, 23:42
I'llpullyaout's Avatar
I'llpullyaout I'llpullyaout is offline
unibody strengtheners??
what kind of supports/steel can i make or weld to the "frame" of my XJ to help it out?? I'm gettin the cracks above the doors and under the top corners of the hood. HEEEELP!!
Old September 23rd, 2005, 23:52
sidriptide's Avatar
sidriptide sidriptide is offline
nobody of any consequence
Re: unibody strengtheners??
not sure what you want to use specifically but use the rear-most LCA bolt and the front leaf-spring bolt as anchor points too. that will tighten up the chassis a lot.
Old September 24th, 2005, 00:02
BrettM's Avatar
BrettM BrettM is offline
http://www.tntcustoms.com/webv2/default.asp#
jonboy's Avatar
jonboy jonboy is offline
these https://lx102.siteturn.com/%7Embarne...chassiskit.htm
or these http://tntcustoms.com/CatalogItemDetail.asp?id=27
or these http://www.detoursusa.com/xjrokslyders.php
or fab your own
Old September 24th, 2005, 06:54
devildog0's Avatar
devildog0 devildog0 is offline
3"x3" angle iron
Old September 24th, 2005, 11:10
C85D4x4's Avatar
C85D4x4 C85D4x4 is offline
NAXJA Member #1311
Hey, I always wondered if anyone has tried some how directly connecting the frame rails together(not just the trany cross mount), making it "more like" a actual frame?
Couldnt this help some how?
Old September 24th, 2005, 20:23
C85D4x4's Avatar
NAXJA Member #1311
anyone?
Old September 24th, 2005, 20:29
ren's Avatar
ren ren is offline
You mean like an MJ back under the bed area?
Old September 25th, 2005, 19:36
C85D4x4's Avatar
NAXJA Member #1311
yea!
Old September 25th, 2005, 23:28
C85D4x4's Avatar
NAXJA Member #1311
iv never seen what it looked like, can you cut 1 off and put it on a xj?
Old September 26th, 2005, 00:37
ren's Avatar
ren ren is offline
No, I don't think that you can just cut off the rear of an MJ and mount it under the XJ. The bellies are very different in this area on the two trucks. However, you might try looking under different types of trucks for ideas that would work. I am just adding some "box" x-members under my '88 limited to make it stiffer in the rear, and give a better place to mount the rear shocks. I am making them out of 2" sq. tubing. I am placing one in the back, and the other is going right behind the "step" under the rear seat.
Old September 26th, 2005, 21:35
pair8hd's Avatar
pair8hd pair8hd is offline
I welded in a cross member between my sleeved frame rails so I could mount my traction bar to...
Old September 27th, 2005, 11:45
C85D4x4's Avatar
NAXJA Member #1311
Nice!
Old September 28th, 2005, 14:26
Jeepin Jason's Avatar
Jeepin Jason Jeepin Jason is offline
NAXJA Member #1100
Hey Alex, do you forsee any issues having the traction bar hang down that low under the axle tube?
Old September 28th, 2005, 15:10
IntrepidXJ's Avatar
IntrepidXJ IntrepidXJ is offline
NAXJA Member #647
looks pretty close to the diff and doesn;t hang any lower....and if anything, would protect the driveshaft/yoke. looks like a good spot to me.
Unibody? Jeep Modified Tech Discussion 19 September 28th, 2012 14:27
Welding to unibody bluebeast Advanced Fabrication and Engineering 19 July 3rd, 2005 21:27
How much can a unibody take jeepguy97 OEM Tech Discussion 4 January 17th, 2005 21:26
opinions on frames under unibody BUCKYXJ Modified Tech Discussion 13 July 18th, 2004 11:19
welding to unibody... jjvande Modified Tech Discussion 12 December 26th, 2003 13:59
