Old August 30th, 2004, 17:26
AzRick's Avatar
AzRick AzRick is offline
Tube bending tips/tricks??
I just picked up a new NE5 tubing bender (the upgraded version of the Model 3 bender), and an 1.5", 5.5 CLR die, from MTech supply in Mesa. WooHoo
I plan on building a 6 or 8-point internal cage for my new 88 XJ project. I am confident in my fabrication skills, as I've built my own steering, suspension and pretty much everything else on the 2 XJ's I've owned, as well as all the welding on FlexyJoes rockkrawler coilover kit, and numerous little jobs for friends.
The problem is I've never touched, or even seen a bender in action before.
I'm pretty sure I know what I want the end result to look like (placement of spreaders, etc...), and I'm pretty sure I know what I need to do to build a safe roll cage (lots of trianglation, mounting points, etc...).
What I'm looking for is any tips or tricks anyone might have for me about measuring, bending, cutting or notching, or any other info that might be helpful to me, or others who may be looking to do the same thing. With the cost of steel these days, I'd like to keep waste to a minimum.
Thanks,
Rick
Old August 30th, 2004, 17:30
xj92's Avatar
xj92 xj92 is offline
Re: Tube bending tips/tricks??
Bendin' Tube 101 from Pirate4x4
I've never bent tube either, but I came across this a long time ago. Hope it helps.
Old August 30th, 2004, 17:32
RCP Phx RCP Phx is offline
JD2's directions are also good!Mines set-up if you just want to play!Measure 20 times,cut once,bend once!!!!!!Also get a piece of "Uni-strut" and tube clamp to set your angle finder on.
BTW,if you bought the manual model your gonna need something real stout to anchor it to!
http://www.jd2.com/Help.htm
Old August 30th, 2004, 17:38
Loose_Nuts_Enterprises's Avatar
Loose_Nuts_Enterprises Loose_Nuts_Enterprises is offline
I use this method exculsively. Works like a champ!
Dan
Old August 30th, 2004, 17:48
XJJPR XJJPR is offline
Rick,
Best thing for you to do is bring that bender to Texas and let me keep it for you!
hinkley
Old August 30th, 2004, 21:38
gearwhine gearwhine is offline
the pirate method is all right at most in my opinion, but a great way to start.
Get a degree ring for the bender...the make shift angle finder they use is just on eye sight, and a degree ring will make it that much easier and accurate.
I did that method for one of my hoops, and just found it to be a pain. I found the whole layout worthless, and stopped going to it.
I just lay it out on paper, and do my calculations there, check my calcs with measurements again and throw it in the bender when everything matches correctly. As long as you measure correctly and know what calculations to make (basic trigonometry most of the times, 3d bends will take a little heavier trig, but still not hard), you will be fine without laying anything out on the ground.
The only thing worthwhile to me is pirate's first step....knowing how much room it takes to complete a bend.
Once you work with it, you will make up your own method quicker than you think.
Old August 30th, 2004, 21:59
OT's Avatar
OT OT is offline
Maybe you could practice on fence railing. It's cheap and expendable.
Old August 30th, 2004, 22:17
FlexyJOE's Avatar
FlexyJOE FlexyJOE is offline
If you ask me....this whole post is just :next:
And None of the welds have broken on my junk either..... I do think that If he were to give the bender to hinkley, he should be able to use all of his tools/ equipment whenever needed......
Joe
Old August 31st, 2004, 12:57
Goatman's Avatar
Goatman Goatman is offline
I used the Bending Tube 101 instructions for all of my cage and bumber. That system worked very well, and a degree wheel is not needed. A couple of adjustable stands are important, and a level, to keep the tubing level to make the second and third bends. The homemade angle finder that the instructions say to use works very well. You have to get used to the tube springing back a small amount, but the adjustable angle tool does the job.
Have fun. You gonna be ready for Nov?
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old August 31st, 2004, 13:32
JCSXJ's Avatar
JCSXJ JCSXJ is offline
Hey Rick, what do you think the chances are of me coming over and watching/helping/whatever. I'd like to learn alittle before I get a bender. I'll bring the beer. I'm the guy that rode with Joe on axle alley when you guys had your old rigs.
James
Old August 31st, 2004, 14:18
Jes's Avatar
Jes Jes is offline
www.urfracing.com
URF uses the Bending 101 method as well.
I think the most important thing to do is think. Think which way you're bending and when you remove a work piece from the bender remember how it was oriented. That way, when you're ready to do somemore bending on it you reinsert it the right way. I messed up a couple tubes by reinserting the work piece backwards in the bender.
Old August 31st, 2004, 14:26
JCSXJ's Avatar
As far as the notching goes, Mtech Supply has a notcher that notches from
0-60 degrees for $180.00. Harbor Freight has one that notches from 0-60 degrees for $40.00 and then there is the Tube Coping Calculator (free).
If you use the calculator you enter in the sizes and the degree you want and then print the drawing out and wrap it around the tube.
Old August 31st, 2004, 18:48
Goatman's Avatar
Like Jes said, go slow and think. Be sure to put arrows on the tube you're bending to show the direction of the bend before you start......VERY IMPORTANT! The chalk drawing on the floor and the hand made angle tool is all you need.
If you're going to get a notcher, spend the money for a good one or don't bother. I broke the Harbor Freight one I got, and couldn't replace the part, so I had to buy another one. A big waste of money for two cheap notchers that I ended up not even using. Careful cuts and some grinding will get the notching done.
Old August 31st, 2004, 21:28
AzRick's Avatar
Originally Posted by Mark Hinkley
Rick,
hinkley
Wouldn't it be better for you to hop in that fancy house on wheels, drive to Phoenix, and give me the privilege of watching the master fabricator in action??? I could probably get Joe to show you around the town in your spare time here......
Thanks for all your tips everybody, I do appreciate it.
I was thinking of getting the harbor freight notcher, but I'm glad I didn't after reading Richard's reply. I guess I'm just gonna do it the old-fashioned way.
If I can get everything together this week, I may get started this weekend. One of my wheelin buddys is an electrician with a ton of conduit bending experience. He's gonna help, along with Joe.....it could be interesting......
I'll definetely be ready for JV in November.
Rick
Old August 31st, 2004, 23:01
FlexyJOE's Avatar
Rick
Rolling house on wheels......nice...funny too....
Joe
Knock noise from axle tube when braking - last attempt greenlawnjeeper OEM Tech Discussion 11 August 30th, 2004 09:32
(cnc) tube benders around philly area...? gearwhine Non-Tech / Off Topic 10 March 15th, 2004 13:44
Tube doors' cage Abugarcia Modified Tech Discussion 2 February 16th, 2004 16:19
Tube VS Pipe Heep Modified Tech Discussion 3 December 29th, 2003 12:24
How do I remove the dipstick tube from my AW4 pan? goldxj OEM Tech Discussion 2 May 19th, 2003 13:45
