BPB
- Battle Ground, Washington
How much fender trimming will I need to do to fit 33 12.50's on with a 3" lift??? will I have to do welding on my inner fenders? will it look ok?
slujeeper5 said:Oh hey Kraziexj, how do you like those timberline tires? Bigpimpinben, my friend runs 32's on 15x8's on a 3" lifted '00, he had rub with the stock fenders. So he put bushwackers on.With those and a 3" lift you could use 33's easy. But, now his 32's look tiny, I'd say Just buy the lift and tires, and then just test it out and cut as you need to, but dont do it all at once, and especially not before you have all the stuff put on your jeep, cause obviously you dont want to make your new tires look small already, like my friend. Ha, but good luck with that.
Goatman said:4.5" backspacing is the ideal amount for an XJ. That is enough to clear the larger tire on the inside but not stick out far enough to cause more clearance problems on the inside. In most cases, 4.75" to 4.5" is the best XJ backspacing for larger tires.
xj92 said:I can't count how many of these threads I've responded to now
XJeeper05 said:That is true.. and you being who you are I hope to say respectfully that I disagree. Since the wheel-well tapers in, the 33s with a 3" lift have less room at full lock. Trust me. I painted my federwells to find my rub patterns and I really believe he cant run a 33 with 4.5" bs wheels. MIne rub and stick out about as far as that guy on this thread with 4.5" abd 33s.
