Old August 28th, 2017, 23:46
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Ball joint?
I have been getting a clunk under the driver side floor board when turning, primarily when turning slow. Axle u joints are new. Tie rod and all pretty new. I assume it's ball the joint.
How likely can I see movement when it's jacked up and I use a pry bar between the knuckle and gusset?
Old August 29th, 2017, 07:13
90xj06's Avatar
90xj06 90xj06 is offline
Re: Ball joint?
the track bar is connected to the frame rail in the engine bay. and when it goes bad it will clunk when you turn. the rail runs about center down the floor on the drivers side. its pretty easy to check with some help. just have someone slowly turn the wheel and watch the track bar for movement left and right.
Old August 29th, 2017, 07:48
md21722 md21722 is offline
Re: Ball joint?
Yeah between the knuckle and axle C. The lower is a real ball joint and there shouldn't be any movement there. The upper is spring loaded pin that goes up and down to absorb shocks while driving and slop in the lower. Don't use cheap Auto Zone type parts as they are over sized and will enlarge the bores in the axle C. If you find any slop probably do all 4. I'd go with Spicer kits. They cost about $125 for all 4 and last a long time.
Old August 29th, 2017, 18:14
Re: Ball joint?
i have an RE adjustable trac bar re1600 i think, do you think itll still pop? good call on the idea though, i hadnt thought of it as an option.
Old August 29th, 2017, 19:41
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: Ball joint?
Don't know about your Autozone but the ones around me, all their ball joints are re branded Moog.
I think whats causing the enlarged bore in the C's is driving the ball joint sideways because they don't want to use the correct tool adapter.
Old August 29th, 2017, 20:03
Re: Ball joint?
When I was dealing with this problem on a Jeep that was dropped off for some work, I got every ball joint NAPA sold and none were as large as the one that came out. Spicers would just spin. And the old ball joint wasn't splined either. I have used MOOG ball joints in the past and replaced them with Spicers and never had a problem.
Old August 30th, 2017, 07:35
NAXJA Member 4950
Re: Ball joint?
Moog has a problem solver line of ball joints that have a slightly over size housing.
Sound like the parts monkey sold the wrong part. Should have been noticeable on installation
Old August 30th, 2017, 13:01
Re: Ball joint?
It's cheap parts other have had the same problem.
Old August 31st, 2017, 00:32
Re: Ball joint?
thinking this might be the issue, canyon road down left turn to right it was a consistent clunk. new tb end needed maybe.
Old August 31st, 2017, 13:17
denverd1 denverd1 is offline
Re: Ball joint?
My moog joints (From AZ) went in just fine. splined and fit perfectly
Old August 31st, 2017, 21:25
BCKNBLK's Avatar
BCKNBLK BCKNBLK is offline
Re: Ball joint?
md21722-Do you have a Part # for that set of all four Spicer balljoints?
Old September 1st, 2017, 07:16
Re: Ball joint?
Spicer 706944X. One kit per side, so buy 2 to get all 4.
Old September 1st, 2017, 15:43
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Ball joint?
Even if the bar itself is good, the hole where it mounts to on the frame bracket can wallow out and allow the bolt to move around in the hole, causing that sort of pop as well - it's happened to me a couple times.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Ball joint and U joint replacemet weekend Lake919 OEM Tech Discussion 5 May 27th, 2016 20:34
Ball Joint Press for U-joint work workgoats Tools and Garages 19 February 11th, 2013 06:31
BALL JOINT$ Jacobus OEM Tech Discussion 5 April 15th, 2008 00:02
HF Ball joint / U-joint tool half off deal... Ivan Non-Tech / Off Topic 7 May 25th, 2005 17:08
Ball joint / axle - u joint replacement rail351 OEM Tech Discussion 7 September 21st, 2003 15:50
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
