Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old April 26th, 2012, 10:42
sweetjeep sweetjeep is offline
Re: VW TDI into a 99 XJ
Originally Posted by Super mud View Post
that is funny as shit
Don't diesels before a certain year not have emmisions? Maybe it's just trucks but I've heard it more than once. I would still be satisfied if you were only able to drive it in your fantasy land (backyard) when its all done.
At least in the People's Republik of Taxachusetts the rules are kinda funny. We, more or less follow the rules in California. So, like I said, I still don't know the answers yet.
Old April 26th, 2012, 10:43
Pictures.
I hope.
http://s488.photobucket.com/albums/r...DI%20Cherokee/
Old April 26th, 2012, 10:46
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
To post the pictures within the thread simply click the link below your image in your album. Click the IMG tag link. It will copy for you and you paste it into the text box when posting.
Old April 26th, 2012, 10:47
Lowrange2's Avatar
Member# 2368
Old April 26th, 2012, 10:48
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
You'll need to plug into the computer for a 99. In a year or two, probably won't - iirc 96s and 97s no longer require plug-in at this point, I know 95s don't.
What bellhousing is that? It almost looks like a Jeep one, but it's too clean...
That engine looks really really small in the engine compartment for a big iron I6. Must be great to have all that space to work.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Lowrange2's Avatar
Member# 2368
Man, you could store a dead body with all the extra space under the hood!
Old April 26th, 2012, 12:29
Yeah. It's ironic. There is a tonnage of space in the front and on the sides. But the turbo location required the frame to be notched and the upper axle control arm currently contacts the actuator for the turbo. So magic will have to occur there. I have pictures, but they induce vertigo if you don't understand what you are looking at.
The pictures you see are with a 2" lift. I don't really care to go higher than 3" for the sake of daily driving. So I think I am going to look in to a long arm 3 link.
On the driverside the A/C compression is close as hell too. But it does clear.
The motor is also needlessly tall. Or more specifically the oil pan is needlessly LOW (causing great grief in the VW community) and I have concerns about it contacting the axle. But I will run the suspension numbers later do determine what, if anything needs to be done.
I contemplate a psuedo dry sump oiling system so I can carry more than 4 quarts. Or leave the pan wet but add a massive tank somewhere in line so I can have a 10 quart total capacity. And possibly shrink the pan at the same time. These are pipe dreams at the moment.
Don't fear the cleanliness of the bellhousing.
I added a couple more pictures to the album.
http://i488.photobucket.com/albums/r...fromrear-1.jpg
http://i488.photobucket.com/albums/r...belowfront.jpg
Old April 26th, 2012, 12:51
Lowrange2's Avatar
Member# 2368
Just add the IMG tags to the front and end of the URL you posted...
Old April 26th, 2012, 13:01
kastein's Avatar
That looks really strange with the oil pan at an angle. I suppose it was designed to fit into a FWD vehicle transverse mounted (at least if I remember what those engine compartments look like stock.)
Old April 26th, 2012, 13:07
deucestudios's Avatar
deucestudios deucestudios is offline
Cool project.
Old April 26th, 2012, 13:16
Vanimal's Avatar
Vanimal Vanimal is offline
is that rotation normal for a tdi? never seen an oil pan tilted like that.
Originally Posted by GSequoia View Post
I always remember to brace myself before doing moderately tight work and get off when really cranking.
Old April 26th, 2012, 13:50
That's only 10 degrees more canted than normal. Evidentally it's a "1g motor" as the van guys mount them directly on their side for use in the old busses and such.
If you look at the drain plug, it's roughly right where it's supposed to be. And what would normally be the leading edge has a pretty significant ramp on it to funnel the oil back.
Old April 26th, 2012, 14:01
NW99XJ NW99XJ is offline
Thats a frickin' TRIP to see that much room in the engine bay... Cool project for sure... I'll be keeping tabs on this one!
Old April 26th, 2012, 18:01
What I meant to post earlier.
Old April 27th, 2012, 07:51
XJCasper's Avatar
XJCasper XJCasper is offline
NAXJA Member #1042
I actually might hate you.
How easy is a 2000 TDI to cover to biodiesel or vegi oil?
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
