Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Jeep Picture Showcase
Jeep Picture Showcase Just a place to post (show off) your Jeep or your modifications images.
View Poll Results: VOTE NOW for August 2011 ROTM
Ba-Riedo 27 12.56%
5spd_xj 52 24.19%
blondejoncherokee 12 5.58%
Kiefer316 60 27.91%
Letterman 64 29.77%
Voters: 215. You may not vote on this poll
Closed Thread
Old August 4th, 2011, 08:43
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Member #674
FINALLY, VOTE NOW for August 2011 ROTM
Same rules as always, see the sticky at the top of this forum for full rules.
No theme this month.
Next month will the summer adventure theme. See thread in adventure forum for more details.
  #2
Old August 4th, 2011, 09:51
Ba-Riedo's Avatar
Ba-Riedo Ba-Riedo is offline
has frame envy
Re: Official August 2011 ROTM submission thread
Year / Make / Model: 1998 Jeep Cherokee XJ
Drive Train: 4.0L, AW4, 231 tcase w/ AA SYE and Tom Woods DS, Tera 2lo mod
Front Axle: Narrowed HP Dana 44, 5.13 Yukon Gears, ARB,
CRANE diff cover, West Texas offroad hydro assist, Dedenbear knuckles, Alloy shafts, CTM joints
Rear Axle: Ford 8.8, CRANE diff cover, 5.13 Yukon Gears, Detroit locker, Dutchman Alloys
Suspension:
4.5 inch RE coils up front
4 inch BOR leaf packs out back
HD Offroad Engineering shackle relocation brackets
Extended lift shackles
Fox 2.0 Reservoir shocks on all corners
Teraflex Speedbumps on all corners
BNS Fab custom 3 link using aluminum BUNK links
Wheels / Tires: 35" Goodyear MT/R's
TrailReady 15 inch beadlocks
Armor:
Those Guys hybrid roll cage, tube flares and rocker replacements
Custom lower door guards
THOR rear quarter guards
Assorted skids and braces
Front winch bumper
YJB fab rear bumper
Extras:
Master-Pull 5/16ths Superline XD winch rope
WARN 9.5ti winch
Vision X rock lights
Cobra CB
Icom race radio
Bucket seats and Crow 4pt harnesses
Master-Pull recovery gear
Hella 500 lights
-Alex
  #3
Old August 4th, 2011, 14:46
5spd_xj's Avatar
5spd_xj 5spd_xj is offline
<<the good ol days
98 2 door XJ
Front Axle-
89 Ford D60
- 5.38 gears
- welded spiders/carrier
- custom brackets
- full crossover steering with PS high steer arm and 1.5" DOM with heims
- SOLID diff cover
Rear Axle-
78 Ford D60
- 5.38 gears
- Detroit Locker
- custom brackets/truss
- Yukon 35 spline shafts
- Chevy discs
- SOLID diff cover
Front Suspension-
Custom built 3 link w/trackbar
- 2" x .250" wall DOM for all links
- 1.25" Johnny Joints/heims at all ends
- coils net about 5.5" lift
Rear Suspension
Custom built double triangulated 4 link
- 2" x.250" wall DOM for all links
- 1.25" Johnny Joints at all ends
- stock XJ coils at about 5.5" lift
Drivetrain Specs
Motor
- Throttle body spacer
- K&N cone intake
- Brown Dog poly mounts
- full 2.5" exhaust
Transmission
- stock AX-15/stock clutch
- poly trans mount
Transfer Case
- ATLAS II with 3.8:1 low range
Driveshafts
- Tom Woods rear DS with flanges and 1330 joints
- stock XJ shaft shortened and has a 1310/1330 conversion joint
Wheels/Tires
- 37" BFG Krawler Red labels- sticky sticky!
- painted H2s
Hydro Assist
- PSC ram
- AGR steering box
- AGR pump
- PSC 4.5" pulley
- PSC cooler
- CROK steering box brace
Odds n Ends
- HD Offroad Stiffeners
- 2x5" rocker replacements with 2x2" legs to framerails
- front crossmember replaced with boxed steel and tied into JCR bumper plates, with 2" reciever hitch
- Cobra 29 LTD CB Radio with FireStik antenna
- stickers
Also have a Warn XD9000 with MasterPull synthetic line (Thanks Alex! ) but not shown in the pictures since I was having problems with solenoids.
  #4
Old August 5th, 2011, 13:10
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Front Axle-
89 XJ dana 30-
4.88s
detroit TruTrac
currie steering
alloy outer seals
LCA skids
pass side UCA truss
ruffstuff cover
27 spline chromos
Rear Axle-
currie HP ford 9"
4.88s
Detroit Locker
35 spline shafts
8.8 discs
5 on 4.5 , XJ width
Front Suspension-
TNT long arms/pan
RE coils
JKS quikcer discos
edelbrock monotube reservoir shocks
Rear Suspension
rustys 3.5" leaves with 3 additional stock leaves
RE 1" shackles
10" 5150's
Motor
MORE mounts
mostly stock,
Transmission
-stock aw4
with better cooler
Transfer Case
231 with HD sye
Driveshafts
CV rear with 8.8 flange
stock front
Wheels/Tires
35" pro comp xtrem terrains
cheap balck steelies
steering:
AGR 4 bolt steering box
JCR 4 bolt inner plate
rustys steering box accross frame brace
RE across frame trackbar brace
RE HD trackbar
winch bumper mount works as an outer plate
Odds n Ends
-ruffstuff Stiffeners
- 2x6" rocker replacements
-winch bumper with Tmax 9000
bottle opener on front bumper
roofrack
rear wrap around bumper with cut out quarter panels for quarter panel sliders
- stickers
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
  #5
Old August 5th, 2011, 22:14
Kiefer316's Avatar
Kiefer316 Kiefer316 is offline
1996 jeep cherokee
4.0L
K&N Intake
Banks header
Flowmaster muffler & High flow cat
AW4 auto
NP231 SYE and stock shafts F/R
Lebaron Hood vents
Suspension:
5.5" RE coils
RE drop brackets with braces
4.5" RE leafs 2" Rusty's Shackles
Steering:
Rusty's OTK kit
Front axle:
D30
4.56's
ARB
Superior Alloy shafts
Bilstein 5150's
Rear axle:
D44
4.56's
ARB
Alloy shafts
Skycrapper shocks
Armor:
Stock T-case and gas tank skids
Custom rock sliders
Front bumper unknown brand
Trail ready rear bumper
JCR light boxes with Cool LED tails.
Tires and wheels:
35" MT/R's with kevlar
15" MRT bead locks
Sure theres more that I am missing. Thing has changed quite a bit since I first got it. And It continues to change!
Pic with old stuff on it.
  #6
Old August 7th, 2011, 11:46
Letterman's Avatar
Letterman Letterman is offline
2000 Limited Edition Jeep Cherokee
65,000 miles
Rear 35 spline ARB 5:13's Dana 44
Front 30 spline ARB 5:13 Dana 44 with manual hubs
Atlas II 5:1
Custom home made Try-Link rear suspension
RE 4.5 coils with front Alco Pro's
37" MTR's on Walker Evens Bead locks
Custom front winch mount bumper
Warn 9000 winch and masterpull rope
Custom home made roll cage
1" body lift
1" moter mount lift
Anti-Rock sway bar
Rubicon Express track bar
Currie drag link and tie rod
Custom home made oil pan skid
Night rock lights
Rubicon Express 62mm throttle body
On-board york air compressor
Hand throttle
Gen-Right crawler gas tank
Shreakworks rockers
Mastercraft seats
B&M short throw shifter
Custom rear bumper
Skid Row Offroad Steering Box Skid
Sony speakers
5100 Bilstein shocks
Cobra 75wxst CB Radio
G&G Offroad custom bump stops
Four wheel disk breaks
Custom URF Racing hand made bumper sticker
and more . . .
  #7
Old August 16th, 2011, 20:43
Cottontail's Avatar
Cottontail Cottontail is online now
Three-De Off-Road
When is this poll going to open? It's halfway through August already!
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2013 WKII (SUZIE)...2006 XK (TOW RIG)
  #8
Old August 17th, 2011, 08:19
kf_chris's Avatar
kf_chris kf_chris is offline
All nice rigs guys
  #9
Old August 17th, 2011, 11:23
Bryan C.'s Avatar
Member #674
No internet at home, and I was out at Sierrafest for part of last week.
Trying to get this poll going while at work hasn't worked out very well for me.
  #10
Old August 22nd, 2011, 08:38
Bryan C.'s Avatar
Member #674
Time to vote!
Time to vote! (finally)
  #11
Old August 22nd, 2011, 16:49
RoyalXJ's Avatar
RoyalXJ RoyalXJ is offline
Re: FINALLY, VOTE NOW for August 2011 ROTM
too bad letterman drives a tj
Project- #14 97 3.5" LA, Built 30/8.25, 35" MTR Kevlars.
  #12
Old August 22nd, 2011, 18:03
chedisme chedisme is offline
whats with the one pic entry's?
  #13
Old August 22nd, 2011, 19:00
5spd_xj's Avatar
<<the good ol days
Sorry, this was supposed to be my second picture but it didn't show up correctly
  #14
Old August 22nd, 2011, 19:36
ktm racer 419 ktm racer 419 is offline
i voted for 5spd_xj because:
1: he has a throttle body spacer
2: he has no rear shocks because i took them when he wasnt looking.
3: he has 120 total dana's. the next runner up only has 88 dana's.
  #15
Old August 22nd, 2011, 19:52
tbburg's Avatar
tbburg tbburg is offline
Ah,.. Letterman's got the elusive round-headlight Cherokee.
Wait! Didn't they call that a Libert-. . .
Closed Thread
Rate This Thread:
VOTE NOW for July 2011 ROTM Bryan C. Jeep Picture Showcase 47 August 4th, 2011 18:10
VOTE NOW for June 2011 ROTM Bryan C. Jeep Picture Showcase 51 July 6th, 2011 20:29
VOTE NOW for May 2011 ROTM Bryan C. Jeep Picture Showcase 43 June 7th, 2011 20:48
VOTE NOW for February 2011 ROTM Bryan C. Jeep Picture Showcase 53 February 22nd, 2011 10:30
VOTE NOW for August 2010 ROTM Bryan C. Jeep Picture Showcase 40 August 26th, 2010 12:54
