Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Jeep Picture Showcase
Jeep Picture Showcase Just a place to post (show off) your Jeep or your modifications images.
View Poll Results: VOTE NOW for August 2010 ROTM
tbburg 23 14.74%
1708Race 45 28.85%
tone 7 4.49%
Loose_Nuts_Enterprises 74 47.44%
GrimmJeeper 7 4.49%
Voters: 156. You may not vote on this poll
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old July 30th, 2010, 07:18
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Member #674
Poll is open and ready for voting to begin.
This month's theme will be for Jeepspeed/prerunner type rigs. All submissions must be approved prior to the start of the voting. Post up your rig first, any rigs submitted that do not comply will be deleted.
Same rules as always. First 5 red letter names to submit 2 recent good quality photos and a full spec list will be votes on. Winner gets their pic on the front page of , will qualify for the rig of the year vote in December, and will be featured in an upcoming calender.
This thread will open on August 2nd, around 5:00 Pacific time.
Good luck!
Old August 2nd, 2010, 19:36
tbburg's Avatar
tbburg tbburg is offline
Re: Official August 2010 ROTM submission thread
BITD 7118 2WD 1987 Jeep Comanche
Run by Zoomy97acr and Tbburg
At the '09 Parker 425,...
on (or above ) the course:
in line at Tech/Contingency:
Photo credit: BajaCurt
Specs:
Drive train:
stock 4.0, pacesetter header, custom air cleaner/air tube
AW-4, B&M Shifter, remote aux. cooler in bed.
Rear axle: Dana-44 trussed, 4.56 gears, spool.
Front 2WD beam axle, trussed.
Suspension:
Front: rough country 3" Wrangler springs, fox 2.5" remote res. shocks, strap limited to 12" travel(class requirement)
Rear: Deaver leaf springs, custom pack, fox 2.5" remote res. shocks, strap limited to 14" travel(class requirement)
hard rubber bump stops, front and rear(class requirement)
Wheels/tires
33x12.50-15" BF Goodrich Baja TAs, American Racing Outlaw IIs.
Chassis:
Score legal safety cage, rear cage bracing extended to shackle mounts
Dual spare tire mount in bed, 32 gal. fuel cell
Body:
Hanneman fiberglass front fenders, & hood, TJ wrangler rear flares.
Tailgate delete, Custom rear "Nerf" bar/bumper.
Interior:
Suspension racing seats
5-pt safety harnesses
window nets
Parker pumper filtered/fresh helmet air system
"Entertainment" systems:
PCI radio
2 place intercom.
Lowrance GPS
2 x 2.5 lb fire extinguishers 1 in cab, 1 in bed.
Lighting equipment:
4xKC Day-lighters above cab.
4 Hella 500s on front bumper.
More photos on the web:
Vegas to Reno 500 '08
http://durkadurka.net/photocart/inde...iewImage=23425 6 pics on course
Parker 425 '09
http://photoahead.com/photo-cart/ind...iewImage=16998 5 pics on course
http://durkadurka.net/photocart/inde...iewImage=42191 3 pics on course
http://www.flickr.com/photos/bajacur...7613501821995/ 5 pics in contingency
http://www.flickr.com/photos/bajacur...7613501821995/ six pics at pit one
Old August 3rd, 2010, 20:55
1708Race 1708Race is offline
1708 Jeepspeed racer
Winner 2009 Parker 425
Winner 2009 MORE Chili Cook Off
Winner 2010 Parker 425
Winner 2010 Mint 400
Winner 2010 MORE ORAF 500
Current 2010 Jeepspeed points leader
Drive train:
2002 TJ 4.0L w/ ported & polished Clifford built head.
Mild custom ground Clifford cam
MSD OffRoad6 ignition
Currie HD motor mounts
MORE Bomb proof block side mounts
Gibson header, Flowmaster muffler
Custom in cab cold air intake w/ UNI 2 stage filter
Anaheim Gear Built NP 3550 manual 5spd
Currie F9 with backbrace, 6.30 gears, spool.
Currie 2WD front beam gusseted and trussed
Suspension:
Front: RE1345 – Coil Springs, King 12”x 2.5” Triple Bypass shocks, Fox 2” Hydro Bumps, strap limited to 10” travel
Currie; CE-9701 Currectlync HD steering, CE-9037X Steering gear box brace, CE-9120HD Trac bar, CE-9102 Upper control arms
Skyjacker; 6”Subframe and lower arms with Currie JJ ends
Rear: Deaver “Jeepspeed Race Pack”, King 16”x 2.5” Tripple Bypass shocks, solid rear bump stop, strap limited to 12” travel
Wheels/tires :
33x10.50-15" BF Goodrich Baja TAs
15”x8” BLACKROCK Desperados
Chassis:
Custom SATO Bros cagework
22 gal. fuel cell
Interior:
Twisted Stitch; Racing seats, Window nets, Tool Bags
Crow 5-pt safety harnesses
Driver and Co-driver Parker pumpers
PCI radio and intercom
Lowrance 7200C GPS
GoPro HD in car video camera
First aid kit
Front interior fire extinguisher
Rear exterior accessible fire extinguisher
Lighting:
2 Soltek BajaDesigns 8” floods
2 Soltek BajaDesigns 8” spots
Total weight= 3900 lbs
Thanks for your consideration,
Eric Helgeson
Team 1708 Express Racing
Old August 4th, 2010, 11:22
tone tone is offline
1997 JEEP Cherokee Dual Purpose DD
Started its life off a 2wd and is now a 4wd
DRIVE TRAIN:
Stock 4.0L
AW-4
NP231 w/ SYE
D30 Front stock 3.55s
C8.25 Rear stock 3.55s
ENGINE:
Brown Dog Motor Mounts
Performance Distrubutors Live Wire Kit
K&N Air Filter
Optima Red Top Battery
Flow Kooler Water Pump
Rustys Flow Master Exhaust Kit
SUSPENSION:
Rubicon Express Long Arm Kit
Deaver Coils
Deaver Leafs
7100 Bilstein
WHEELS/TIRES:
33x12.50X15 Dick Cepek FC2
American Racing Black Steelies
CHASSIS:
AJs Rock Sliders
BODY:
Hanneman Fiberglass Front Fenders
Light Bar with 2 Hella 500FF Lights
INTERIOR:
Cobra CB Radio
Spare Tire Mount/Hi-Lift Mount
Tool Box
Spare Parts Bag
MISC:
PA Speaker
T&Js Currie Anti-Rock
T&Js Steering Box Brace
T&Js Upper Front Shock Mounts
Squirrel80 CUSTOM Lower Shock Mounts
SoCal Desert Rats Blood Sweat n Tears...
Thanks to everyone who has helped me out along the way!
Old August 4th, 2010, 11:35
Loose_Nuts_Enterprises's Avatar
Loose_Nuts_Enterprises Loose_Nuts_Enterprises is offline
96 XJ 4wd Pre-Runner for #1706 DJ Racing
San Filipe 2009 Baja 1000
Powder Puff Race for the Cure 2009
Specs:
96 Jeep XJ
Drivetrain:
Ford 302, fuel injected, moved 7" to rear, custom firewall
Art-Carr C4 Trans, Reverse manual valve body, low ratio planetary set, 300M main shaft, Art-Carr shifter
Atlas II transfer case 3.8:1 ratio
Axles/Suspension:
Dana 30 front axle, trussed custom mounts, Detroit Locker, 4.88 gears custom 6 lug dana 44 hub conversion and brakes
Rubicon Express long arms, custom crossmember
Rubicon Express 5.5' coil springs
King 2.5"x12" double bypass shocks, strapped at 13" of travel
Radflo 2"x4" hydraulic bump stops
Ford 9 inch rear axle, trussed
31 spline Dutchman chro-moly axle shafts
4.88 gears, Detroit Locker, disc brakes
4 link trailing arm suspension, 1 1/4" heims everywhere, except bushings at frame side of lowers
King 2.5"x14" coilovers
FOA 2.5"x16" triple bypass shocks, strapped at 18" of travel
Interior:
Full roll cage, from front bumper to rear bumper (lots O' tube)
Custom sheet metal dash with gauges, switches, resettable circuit breakers, Lowrance 540C GPS, Kenwood Race Radio, Rugged Radios Intercom and headsets, XM satellite radio, Link-Arc on-board welder mounted in dash, co-dog telescoping handlebar
Kirkey aluminum race seats
PRP 5 point harnesses
Extras:
(4) VisionX HID's on upper light bar Converted with Baja HID kits
Hella headlamps with Baja HID kits
(4) Kragen 4" HID's on front push bar
37x12.50 17 BFG KR project race tires or 36x13.50 16 Interco Irok's on Champion bead locks
Hanneman fiberglass fenders and bedsides
Rear amber collision light
More build pics here
Old August 5th, 2010, 08:33
crazyjim's Avatar
crazyjim crazyjim is offline
mmmmmm links
Old August 7th, 2010, 03:01
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Dead man walking
not enough rigs yet? lets get this going sheesh.
well screw it I'm in
95 XJ sport, "Frankie" (named after a chick in my JR High school that used to beat up guys )
front:
JCR prerunner bumper
2 6" procomp lights converted to HID
4.5" fabtech coils
1.75 poly spacers
hanneman flat top 6" bulge glass fenders
blown out crappy procomp resevoir shocks
fabtech lower arms
stock uppers
procomp trackbar w/ 5/8" heim at the frame end
rear:
detours USA rear bumper
RE 4" leafs
generic 2" shackles
rear shock hoop
14" King 2.5" prerunner series smooth body resevoir shocks
33x10.50x15 BFG Baja T/A tires
Johnson Valley
Gorman OHV Area
I'm in the process of moving everything over to a new body, she didn't like being beaten so hard without reenforcement. I sent her out with a bang though, vid in my sig
Old August 7th, 2010, 17:58
Bryan C.'s Avatar
Member #674
Re: VOTE NOW for August 2010 ROTM
Poll is open
Old August 8th, 2010, 11:26
Wow... not a very good start for the 1708
as a newbie to the site I guess I don't have many friends.
Dans XJ is pretty cool... but we're used to the DJR guys running up front. We eventually catch and pass them
Check out our Parker 2010 in car video to see just how ole blue runs...
...with special emphasis around min 4:53
Old August 8th, 2010, 12:18
OverlandZJ's Avatar
OverlandZJ OverlandZJ is offline
NAXJA Member # 101
Very cool rigs.. best of luck to you all.
Running one of these rigs must be a blast!
Old August 8th, 2010, 13:13
jakeWI jakeWI is offline
voted!
Old August 8th, 2010, 15:45
crazyjim's Avatar
Haha Eric it's not about having friends. Its the fact his xj is linked on 37's with a v8. No class rules to follow. Your XJ is a work of art. I've seen it run!
Old August 8th, 2010, 16:53
tbburg's Avatar
Yep,... Looks like links are going to take the day,... or at least take an early lead.
Don't feel bad -Race, I think the only reason the 7118 truck is ahead of you is because of the loyalty the Comanche guys have. When I saw the pics you posted, I figured the 1708 car was going to walk away with it.
Old August 8th, 2010, 23:12
crazyjim's Avatar
FWIW I think you should have used the full size versions of these pictures:
Old August 9th, 2010, 11:50
in4aride's Avatar
in4aride in4aride is offline
X2!!!
but its all good, got my vote, looks like you drive like a maniac! i dig it
Grab a gear, let's go.
Rate This Thread:
VOTE NOW for June 2010 ROTM! Bryan C. Jeep Picture Showcase 21 June 18th, 2010 12:15
VOTE NOW for May 2010 ROTM Bryan C. Jeep Picture Showcase 62 May 25th, 2010 09:05
VOTE NOW for April 2010 ROTM Bryan C. Jeep Picture Showcase 37 April 27th, 2010 13:04
SoCal Chapter's ROTM - March 2010 - Vote Now! djblade311 SoCal Chapter 61 March 31st, 2010 08:46
August ROTM WebEditor Jeep Picture Showcase 9 September 24th, 2008 07:23
