redrider2911
- Yakima, WA
K guys, so after posting up my true 3-Link design I had alot of members asking about a true 4-Link. I got on the ball and realized I could use the same concept of the 3-link crossmember and just mirror the upper mount to the other side. There doesnt look to be any apparent clearance issues. Luckily is seems Snyder has volunteered his Jeep to do the first mock up of this kit. The lower links are going to be the same as the 3-link using 7/8s heims or the option of Ballistic's poly bushings at the axle end. On the upper link there will be a 7/8s heim on the frame mount and a "U" shaped adapter on the axle side that will bolt to the stock UCA mount at the diff and on the passenger side (or if you have the weaker sheet metal mount on a non-disco axle you can purchase a new one). The reason I call it an adapter, for lack of better term, is because unlike how most kits have a welded on "U" instead I have designed this piece with a threaded stud so that it will still thread into the UCA and act as a turn-buckle for adjustments. The only thing I can honestly say that I dont like about this kit is you have to drill absolutely strait through the frame rail to match the whole on the other side. This tends to be difficult because the frame rail isnt exactly square. If anybody has ideas for improvement on this aspect of the design feel free to chime in.
If you guys have any questions or thoughts feel free to let me know.
Thank you, Kris Froehlich of Froehlich Suspension Technology
K so on with the 3D Models.
