pancake
- Seattle, WA
Under the hood, on passenger side. I don't know what the fuse goes to, but it blows quite often now. It used to happen once in a while when I went into reverse, but now it happens while driving. I blew 3 fuses on the way to work this morning. I don't have a service manual with me, it's in CA and I'm in WA.
It's a 15A fuse located in the block of 10/15/20/25A fuses. If you look at the bottom of the fuse box cover, it is next to the Fog Lamp & A/C Clutch section. When you look at the fuse box inside the Jeep it's the 1st row of fuses. The order goes 15A-[15A(this one)]-25A-15A and the problem child is the 2nd 15A from the left. Anyone have any tips on what this could be?
