Old February 13th, 2018, 18:29
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: Ball joint?
Originally Posted by 4x4JeePmaNthINg View Post
Anyone run core 4x4 Trac bar and bracket, stage 3, any good. I changed the heim a ways back but it's popping again and if it's the bar/ upper bolt I'm going to a double sheer bar.
Mainly pops turning left
I am running a RE track bar and a Core 4x4 double shear bracket.
I just turned the heim ninety degrees, added a pair of misalignment spacers to fill most of the width and reduce the bolt down to a 1/2" bolt. A grade 8 1/2" bolt, grade 8 nylock nut and a few grade 8 washers finished the job. I have three washers on the inside of the bracket to finish filling out the gap.
I think you could also run a Johnny Joint in the RE track bar.
The Core 4x4 bracket required me to tighten the heim all the way into the track bar in order to center the axle. That will vary according to lift.
Ball joint and U joint replacemet weekend Lake919 OEM Tech Discussion 5 May 27th, 2016 20:34
Ball Joint Press for U-joint work workgoats Tools and Garages 19 February 11th, 2013 06:31
BALL JOINT$ Jacobus OEM Tech Discussion 5 April 15th, 2008 00:02
HF Ball joint / U-joint tool half off deal... Ivan Non-Tech / Off Topic 7 May 25th, 2005 17:08
Ball joint / axle - u joint replacement rail351 OEM Tech Discussion 7 September 21st, 2003 15:50
