Old October 3rd, 2017, 13:35
bradleyheathhays bradleyheathhays is offline
Rubber v. poly sway bar link bushing
Yeah I know this is a nit picky question, but doing some suspension spruce ups on the old 96 XJ and I'm in the middle of looking at front sway bar links. The Moog has what looks like blue poly bushings, whereas the OMIX ADA has rubber bushings.
Problem is I've been trying to go all rubber bushings as I've been told they give a better ride and aren't as noise.
So the question is...should rubber vs. poly matter muich as this junction point...sway bar link to say bar? Should I just go with the Moog w/ poly?
Old October 3rd, 2017, 17:04
sinat01's Avatar
sinat01 sinat01 is offline
Re: Rubber v. poly sway bar link bushing
Go with poly, helps handling a bit, lasts longer too. if they start to squeak, spray some PB blaster silicone spray in them and they will be good to go.
Poly VS Rubber CMAHON Modified Tech Discussion 11 October 14th, 2010 19:05
Poly bushings instead of rubber for RE LCA's? oo7ravisXJ Modified Tech Discussion 6 August 18th, 2008 13:43
Rubber or Poly??.... techno1154 Modified Tech Discussion 18 July 18th, 2008 17:39
poly or rubber rngrfrd2000 Modified Tech Discussion 8 June 11th, 2005 00:13
Sway Bar bushings - poly or rubber? Chancer OEM Tech Discussion 4 October 15th, 2004 08:21
