Old April 11th, 2015, 04:43
nosigma's Avatar
nosigma nosigma is offline
NAXJA Member # 1371
Re: Dana 30 Build: Sleeve, Truss etc.... for 35's
It might rattle if thats all that I had holding it on. Since I also have to back up when high centered on it I need a way to keep it from sliding off the stub tubing. I will be drilling a hole through one side of each stub and then welding a nut inside the stub tube that is welded to the cross member. A bolt will then go into the nut through one side of the outer hoop. I cant cross drill it since I dont have space to remove a bolt that long. This will pull the two pieces together and prevent the outer tube from slipping off when backing up on the skid.
John
VirginiaZJ "Frank, Stop. Don't come down here" Somebody: "Is John in a predicament?"
VirginiaZJ "Well, the front of his Jeep is facing me now" Somebody: "Yeah, I guess that is a predicament!"
Old April 11th, 2015, 13:38
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Edit... Nevermind. Just re read your post.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old April 28th, 2015, 07:44
nosigma's Avatar
NAXJA Member # 1371
The skids have been skinned in 1/8th and are installed.
The front of the skid is supported by a strut on each side that goes up to the frame rail. The rear skid will have a single strut going up to the unibody offset to the driver side. Here is a detail of the strut on the passenger side.
For now its painted with a clear coat. The skids will get a single sheet of UHMW before seeing any rock work.
John
Old April 28th, 2015, 12:28
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
Looks killer man. Im taking some serious notes right now. Spot on.
Old May 9th, 2015, 21:27
nosigma's Avatar
NAXJA Member # 1371
It LIVES
Up on a 42.
Not home yet , but close.
John
Old May 10th, 2015, 18:53
Jbh97009's Avatar
Jbh97009 Jbh97009 is offline
Nice! I love that crossmember & skid
'98 4.0 sport, iroks, and a bunch of other stuff....
'95 4.0 sport, Kevlars, and a bunch of other stuff....
Old May 11th, 2015, 10:34
TheCodeMonk TheCodeMonk is offline
Are you gonna punch any holes in those skids? Wondering if they'll end up catching and carrying a lot of dirt and rocks otherwise. :P
2001 White XJ
3.5" Long Arms (Full Traction) Lift + ACOS and HD Offroad shackle drop, 35x12.5r15, Bushwhacker Flat Flares, JCR Crusader [winch front bumper, non-tire carrier rear bumper, sliders, gas skid), Waggy D44 front w/elocker, 8.8 rear with worn out LSD.
Old May 11th, 2015, 10:40
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
i'd be more worried about them filling up with leaking fluids (in the long term).
one of the leading causes of deaths of 4x4's is skids filling up with leaking ATF, it splashing on a hot cat and flash burning.
Old May 12th, 2015, 22:46
nosigma's Avatar
NAXJA Member # 1371
TheCodeMonk: not worried about rocks and mud. I wash under the rig after almost every ride here in va since there is so much mud. No holes for that.
Cal: Your scaring me. Stoney my best wheeling buddy here in VA had a fire and nearly lost his rig (LJ Rubi) due to an atf leak and fire. I really don't want to put holes in a slider. Damn you bro, thank you bro. Now I need to find a way around that without holes in the skids. First thought is thin aluminum splash shield between the cat and the rear skid.
Old May 12th, 2015, 22:57
cal's Avatar
cal cal is offline
I have 3 3/8" holes in mine. Just enough for no pooling.
Old May 28th, 2015, 22:45
nosigma's Avatar
NAXJA Member # 1371
Got it home yesterday. This build kicks ass. Car Crush (first over) Saturday. Pics to follow. Chaos Fab is awesome.
John
Old June 1st, 2015, 20:18
nosigma's Avatar
NAXJA Member # 1371
Here is the only picture of it from the weekend.
Most folks run the car crush end to end. I had to be first over side to side. I wanted to be first over end to end but we had one vehicle with a crushed A pillar and the risk of it collapsing and causing a roll over for the first vehicle across was so great that we put a fully caged rig up there first. After that it was way too easy to cross end to end.
I got the front end up and over with no "stacking" but the rears needed the tires on the ground since the front was stuck in "ditch" where the roof on the red car was crushed down. Paint is silly slick.
John
Old October 26th, 2015, 20:38
Dragonlich1961 Dragonlich1961 is offline
Hey. Those cars and the xj look familier. This was on memorial weekend right? I was the little white two door runnin on 30s with 3 inches sitting on two turdys.
Old February 26th, 2017, 09:43
redman redman is offline
Nosigma how has your axle held up?
why do i need 35's, A build ? micahtbyrd Modified Tech Discussion 15 August 6th, 2008 00:17
95 XJ Dana 30 - crush sleeve? Blaine B. OEM Tech Discussion 5 May 14th, 2008 18:19
Few pics from my current build, Leaf Front etc Truss AMC20 Etc ~Ace~~ Modified Tech Discussion 4 April 23rd, 2008 16:15
Dana 30 Crush Sleeve? brifro123 Modified Tech Discussion 11 October 16th, 2007 04:54
Dana 30 Crush sleeve???? rEGAL2800@AOL.COM Modified Tech Discussion 5 June 19th, 2005 03:43
