Hey guys. Yeah it sounds MUCH better. Ive been driving it around and all seems well. Its very smooth, and very quiet. When I first start it up while cold, oil pressure is steady at around 50-55psi. Stays there. After its warmed up all the way, pressure while stopped and idling is 30psi, and while driving is a constant 40-45 psi. So I think everything is going good so far. Ive been taking it real easy on it... Figure I would baby it til the 500 miles are up, change the oil and filter, and hand the keys back over.
As for the cause of all this...I think the pump failed. I took a 5 gallon bucket, and put some new oil in the bottom. Just enough to submerge the pick up. Put the old pump in the bucket with the input shaft chucked onto my drill. Oil came out...but it was in consistant and kinda weak looking. Hard to explain. Then I did the new pump, and it actually bogged the drill down once it sucked oil in, and almost shot oil all over me. It came out a lot stronger, and when i slowed the drill down, the amount coming out was nice and consistant. I took the old pump apart, and I honestly couldnt see what could be wrong. But all I know is, it didnt bog my drill down like the new on did, so something is weird with it...
I found some bearing issues while in there, but I think everything was pre-existing to this oil pressure failure. Ill take some pics for you guys that want to see the rod bearings. I should get a chance to do that tonight for ya. I wont do them all like the mains, Ill just snap a few.
Cant say that I had fun doing this...but it feels really good to have saved my mom alittle money. Well... alot of money... Be able to work on cars has a ton of financial benefits!
Dr. Dyno...50k is plenty of time for her to save up and get another car
The stroker plans are for my jeep..which may actually happen this summer. The gears in my head are turning, just need my wallet to spin with em.
WarnFleXJ said:
Being an independant shop technician I have found a bunch of oil psi switch's to be aslo. I believe the proper diagnosis would be to check for the proper voltage at the switch and then a resitance check, It looks Like Mr.Dyno would know about the Diag. procedure
Not sure why we are still talking about the oil pressure sender? There was never a question in my mind that there were actual physical issues, not just a sender/gauge issue. DR. Dyno's quote was basically telling me I wont know til I tear it apart. Which was correct, and in the back of my mind I knew that... Heck, even after tearing it apart I still dont have 100% confirmation on what went wrong.
Thanks again for the feedback everyone! Keeping my fingers crossed that it keeps running like it is now. Its kinda weird to drive it because its so quiet. With the hood up all you can hear is the fan whirring and the injectors ticking away.
Justin
