boise49ers
- Boise,Idaho
I have bought axles from a 93 YJ w/disconnect and I want to put them in my 1988 XJ with the same set up. The YJ axles are larger along with the larger u-joints. Is there anything else I will need to change on the XJ before installing ? Are the seals the same ? I know they say change the seals when you pull an axle, but I've had them out 4 times and never have and they don't leak.When they leak then I will. Thanks for any help !
