Jerry_h
- Minneapolis, MN
How'd you attach the copper or stainless tube to the aluminum output tube without at least a short section of rubber in the crimped on end?[/QUOTE]
I posted some piture links earlier, In the pic you can see the stainless steel line connected to a check valve and then screwed into the fitting welded onto a piece of the original ac line screwed into the compressor.
