sidriptide
nobody of any consequence
- western massachusetts
my wife's 04 WJ is a 2wd model, but the rig is pristine and the price was awesome. besides she doesnt go anywhere when it snows.
however, with me being me, i'm planning for a 4wd conversion at some point . probably if/when the transmission smokes itself, because thats what they do.
is the stock WJ axle hi-pinion or lo-pinion D30?
i've been reading about the WJ control arm mod for XJs and it seems the only difference between the axle housings is the control arm brackets, with the WJ's being wider for the larger WJ bushings.
so the way i see it, if the WJ axle is stock lo-pinion, i can get an XJ hi-pinion axle, swap the knuckles to use my stock brakes, hubs, and steering , modify my CA bushings to fit the smaller brackets on the XJ axle and i should be good to go.
i figure i can do most of this stuff without the wife knowing, until i install the additional shifter.
then i'll have to explain... sometimes it's easier to apologize than to get permission.
overall it looks pretty simple, it really depends what i chose for a front axle i guess.
did i miss anything?
i was told the WJ axle is wider. is that the actual housing measured inside the knuckles, or WMS to WMS?
