Blaine B.
- Northwest Indiana
It is.
This prompts another - related - thought that might be worth checking. If you have a reverse rotation set-up, then you need not only to check the routing of the belt and the direction the fan turns. You also need to be sure, if you replace the water pump, that you have the correct replacement pump. All the water-pump housings are the same shape and fitting (so if you get a stock aftermarket pump it may fit OK, but might still be wrong for your vehicle). If you have a reverse-rotation system, you have to check that the impeller blades of the new pump have an "R" stamped on them. If the impeller blades are angled wrongly then of course the pump won't circulate the water very efficiently, so you'll get overheating.jeeperjohn said:I once put a normal universal fan on my mustang and had huge overheating problems. It turned out that the mustang had a reverse rotation water pump and the fan was pushing the air back into the radiator. Check that the belt is routed properly to turn the water pump correctly.
Blaine B. said:Any comments on the temp of my trans relating to a warm/hot center console below the ebrake lever?
Blaine B. said:When I put the pump in last year, everything was identical to the old pump. But last year I didn't have any temp issues either.
Blaine B. said:I appreciate all suggestions!
I STILL need to get my hands on that contact thermometer so I can carry it with me at all times. As momentarily tested in the past, I believe the gauge is giving me a reading which is too high compared to actual engine temperature! As stated, the gauge was reading above 210 but the thermostat housing was reading about 179-180 degrees farenheit. Go figure, the sender for the gauge is new from the dealership.
Blaine B. said:Wait a second, I never had an aftermarket temp gauge sender. Only the origional and then now an OEM replacement from the dealership.
TMXONR said:It does the same thing with the AC on or off. If I have the AC on and the temp rises, I turn it off and it doesn't make much of a difference.
For the Electric Fan, I am going to say that it is always on, because as soon as I turn the key it comes on.
Can someone take a pic of where exactly I should take the temp. Also I have the Closed system.
Also could this be a sign of a crazy gauge? If I go down a steep hill when at Superlift, sometimes (most of the time, unless its a short hill) the gauge will go into the red, but once I get down the hill and on less vertical land the gauge goes back to where it was.
