Vanimal
- escondido, ca
the heat effected zone is not going to reach far enough to matter, stop being paranoid. it's a sway bar.
Simply put: you should not weld (or even heat) spring steel. Go ask any ME. Sure it may not fail, and may actually last. It is however whether or not your willing to risk a failure and possibly putting your life or someone elses in harms way.
I'm glad it works so far, but only time will tell. Either way, I'd be checking it daily for cracks.
the heat effected zone is not going to reach far enough to matter, stop being paranoid. it's a sway bar.[/QUOTE
It's all good. It just so happens that sometimes the easiest fix isn't always the correct one. :wave:
OMG, let it go. You need to get over yourself. Why don't you use an inconel header on your turbo setups? That would be the proper material for the job would it not? Ask any ME.
I've seen two Currie sway bars fail and it had nothing to do with the arm attachment points, the bar failed right in the center, No-one was maimed or killed.
I used to do 100 hours inspections on Airplanes prior to upgrading to C and D checks on the commercial stuff (737's and up) so to put it simply, do not preach to me about safety or inspection practices.
What actually happened: Boowerks spouted off on design inadequacies because he mistakenly thought I was just another redneck with a welder. He got caught, and now he can't admit he was wrong.
lol what!? Ok I'm done. I need to go weld some leaf springs. lol :banghead:
OH no way! Your an expert too?
His an expert what?
Why does everyone seem so worried about a possible failure? Half the people I know run no swaybar, and the other half have driven on the street with their swaybar disconnected at some point. If you were flat out at the limit in a turn and it failed I could see a problem, but who's diving a lifted xj flat out in the turns anyway?
Sideshow: Looks awesome. Excited to hear reports on how it works.
Vanimal: Here is my link to what I did for a rear sway bar.
http://www.naxja.org/forum/showthread.php?t=1053059
Ha Ha...I agree with you, well a lot of people just have to feel important..they think they are the final word in anything you make..all experts.... lol
goodluck to the OP! I genuinely hope it lasts.
An engineer would not advise to alter the torsion-bar by cutting a ring-groove and reducing the spline engagement. An engineer would not suggest drilling and tapping the torsion bar when it wasn't initially designed for it in the first place. The plain and simple fact is that an engineer would suggest that I not perform this modification all-together. I work in a building with over 1000 engineers, some of them are dumber than a sack of hammers, please don't hold them with such a high regard.If you think what i said was a power trip, i challenge you to ask any engineer worth a damn how they would approach connecting a non hardened, and SPLINED collar to a spring steel torsion beam.
I am and forever will be someone who speaks boldly without fear. Especially when i design and implement engineering solutions for a living. Something that is criticle to the stability of the vehicle should not be halfassed. i am also someone running no sway bars. It is exactly for the reasons xcm outlined however that make this a big deal. If im out of line feel free to talk back, but as far as im concerned you should never weld any heat treated steel unless its a static no-load connection or going to be properly normalized and retreated. But what do i know right?
Thankfully the world doesnt rely on all of the "internet phd's."
The tack welds will break. There is absolutely no exuse for welding the collar to the the arms. How long does it take to drill a couple holes?
x1000. try working with them if you're a machinist or manufacturing engineer. most have zero concept of how to manufacture what they draw.I work in a building with over 1000 engineers, some of them are dumber than a sack of hammers, please don't hold them with such a high regard.
