jeepin' josh
- Spanish Fork, Utah
Ok that was probably not the greatest idea... Something is deffinetly wrong.. Something is rubbing bad and I'm not sure if it's due to my alloy shafts I put on instead of my stock shafts or what... The alloy shafts use a bolt like a grade 8 hex head bolt with a lock washer and they stick in so far I had to remove the whole ebrake system just to get them in and now I think they are in to far cuz I have this horrible rubbing scrapping sound comming from the new disc system.... I know I can grind the heads a bit but that's if I was running the ebrake system... It's not even on the disc brake system yet it sounds like something is rubbing the crap out of my dust shield or the axle shaft is sitting on the spacer... Maybe get new spacers from Teraflex?? They said they enlarged them in thier new kits cuz the older ones moved around and didn't stay centered unless you welded it?? I've got 2 days to fix this plus build my new front axle... Anyone been through this before???
