will a wrangler 6cyl tcase work in an xj, or is the clocking different? i got a hole in my tcase from a malicious rock, it patched with jb weld for the moment so i can drive back and forth to work.
The difference that I have found is that the AW4 output shaft is approx 1/2 inch longer than an AX-15 output shaft. So the input spline (21 or 23) needs to accomodate the extra length from the AW-4 output shaft. If your xj is an aw4 you could add an adapter plate between the ax-15 tcase and the AW-4 or you could pull the input shaft from the xj tcase and put it in the new case.
