OK... time to add more confusion and questions to the mix. Yesterday at an all-you-can-carry junkyard day I saw fit to procure a full set of WJ hardware - knuckles, caliper brackets, calipers, ABS pickups (for my traction control project), drag link, and tie rod. I now know that my dumb luck resulted in me getting Akebono calipers and brackets.
What things look like to me -
* I need to get the JKS spacers (OGS930, weld-on.)
* I need 00-01 unit bearings (I checked, and Timken supplies the same part number for the 01 TJ unit bearings and the 01 XJ unit bearings everyone is talking about. So this post isn't entirely questions... this is an answer/clarification
* For simplicity sake I am following XJEEPER's footsteps and redrilling WJ rotors.
* I need XJ upper ball joints (which are the same as WJ uppers) and WJ lower ball joints.
What I'm not clear on - I think the WJ tie rod is too wide? This is unfortunate, it seems fairly well built and I was hoping to use it. Drag link geometry I'll figure out after I get the rest of the thing put together I guess, since it's not a daily driver anymore I'm not too concerned about a bit of downtime. Another thing, how do you get the JKS spacer located properly to weld it down? I was thinking I would bolt a sacrificial worn-out unit bearing into it to clamp it into place then weld the spacer to the knuckle. Does the JKS spacer only serve to align the U-joint axis with the balljoint axis or does it also locate the smaller-diameter unit bearing flange within the larger hole in the WJ knuckle, as I think I read somewhere? If it's the latter it makes me worry that I may slightly misalign the whole thing if I'm not very careful which would result in the inner shaft entering the differential at a slight angle, possibly wearing the splines / side gears faster than otherwise and putting more stress on the inner tube seal then I would like.
I probably should read a few more threads... I've read this one, userbmx's thread, and the posts in XJEEPER's build thread that are relevant to this. I never really planned on doing WJ steering/brakes as I always figured it was too expensive and not something I needed, but then I got most of the parts required for nearly free.
