Highway XJ
- La Verne
I have 5 inches with short arms and I have to decide, LA's, DB's, or sell it.
I just got a new sig line!every time you drive with 5+ inches of lift on short arms without drop brackets baby jesus cries.
I have 5 inches with short arms and I have to decide.
ah ok. this is the kind of answer i was looking for. i knew it had something to do with travel, but wasnt sure of which was was affected.
quoted for search posterity...The downtravel is a minor thing. The main issue is the angle. The arms force the wheel into bumps, so they aren't absorbed well.
You know how motorcycles have forks angled back? Imagine if they were angled the other way.
Think your tin can creaks and groans now? Imagine after a few thousand miles of the unibody taking the shock of every bump!
Ive got about 7" on a short arm with drop brackets. it rides better than stock, and it flexes like my springs are melting.
I agree that you should just buy the right lift to begin with.
Ive heard somebody else complain about the drop brackets hitting everything. I dont think you guys consider that the angle of the longarms is in the same place as the outer corners of the drop brackets. so, if you are hitting on your drop kit, you'll hit there on your longarm kit. its just the way it is.
You can always build some skids for the brackets if its a constant problem. IMO, the drop kit is absolutely the way to go over a conventional longarm kit.
Of course, ive wheeled the piss out of my setup, and i dont think ive hit more than a handful of times.
You get hung up on drop brackets, not long arms. If anything the long arms just act as sliders and you can still pull forward or backward and not damage anything. Since drop brackets are usually some sort of plate they will dig into the rock or obstacle and possibly not be able to move. If you throttle through it you can risk more damage and tear off the brackets all together.
This kills me ....how are you guys getting hung up on the brackets....it has never happened to me ... i am not saying that long arms are not ...BETTER but at what cost. something eles is were your drive it. I am thinking you guys are rock crawlers, i dont want to start the whole rocks vs mud thing but i dont have the rock option were i am so it is trails and alot of mud... i have never been hung up on the bracket in three years. as far as the way it drives, its a little darty from time to time but can do the hiway at 60 all day. oh and travel is 16 inches untill i unbolt the shock then its 19....i need new shocks .. this set up works great for a lot less money than most long arm kits. i wish i could post pics but i am not alowed
