- Wasatch Range
Mark Hinkley said:How else is he going to drive an XJ with that big of a head? Expecially with that ugly hat on!
hinkley
Spoken by the king of big ugly boths..........
hinkley
Jes said:You do not get the dig.
That is not Fordyce.
You are out of your element.
I say soup Bowl.Jes said:That is not Fordyce.
C-ROK said:I say soup Bowl.
Rubicon.
Know it too well to not know it.
Rubicon.
Hell I've never been on the Rubicon or Fordyce and I knew it was Soup Bowl.C-ROK said:I say soup Bowl.
Rubicon.
Rubicon.
An exo is where it's at. Get one and you will be on your way to hardcore.Big Red said:You're right I see it know. I see the trail going around it to the right. Good eye. I hope to attempt it this summer when I hit the Con again and hopefully Little Sluice if they don't blast it before I get the chance.
After all this talk about the interior cage being dangerous, I think I will do an exo cage on my XJ. That way the body should take less damage and there will be more points along the exo cage to winch from or have some people pull a strap from. I see the spotter in competitions pulling off the roll bar to keep the vehicle from leaning too much and lesson the chance of a slow roll over.
Troy
Rick XTRM XJ said:I get it
Rick
A 4 or 5 point harness fixes you in the seat. There is no sideway movement possible, this is also the reason why you should not add a 4 or 5 point harness to a non-caged vehicle.xjj33p3r said:So, I do understand the point of a seatbelt, but what is different from a normal belt compared to a 5 point harness? I at times like to lean in and look over the steering wheel to see where I'm going, but wouldn't a harness keep you from doing that?
And about sticking your head out the window... I know this guy who just began wheeling his jeep a couple of months ago, started sticking his head out of the window, looking at his tire burning rubber, and he nearly got smacked in the face with a little pebble. I honestly won't do that much, especially when I'm spinning out, but when going slow, I don't risk getting hurt as much. Just my 2 cents.
Quite a bit I would say.xjj33p3r said:Hey Crok, how much did the external cage help in the roll that you had?
C-ROK said:Quite a bit I would say.
The roll:
The bad side after:
The good side after:
