Who has broken a 29spline 8.25 shaft??
am i correct in thinking that since the carrier is directly center in the axle, 1 spare shaft would work on both sides?
anyone know that one?
You'd be correct in your thinking.
true true, i just carry two because i have em and why not bring both. never know whats gonna happen
The only bad thing about moving to a D44 from my 8.25, is having 2 different sized shafts.
The brakes help me forget that shortcoming, though.
HTH
xjrrrdx said:
Is it true that a 27 spline 8.25 is basically like having a D35??
The shafts are the same size, but the axle tubes are much thicker and the ring gear is larger, making for a stronger all-around axle than a d35.
Ramsey said:
if/when i jump to 35's should i invest in dutchmans, also what do they run? dont plan on swapping axles since i just regeared and locked it.
$280/pair
JeepinAudiophile said:
$280/pair
thanks, guess those might be next
