JEEPTUBE
- citrus heights
GO GET SOME UNIMOG AXLES.
Lay off the caps man. Why you gotta go around screaming at us on your first day? Go back to the first post and see if you actually have any info to contribute.(stick with what You know or have tried)JEEPTUBE said:STICK WITH RUBICON OR FULL TRACTION. THERE KITS ARE VERY COMPLETE AND STURDY. ROCK KRAWLER? U GOT TO BE KIDDING ME. THEY SELL THAT 3 CONTROL ARM KIT FOR THE FRONT RIGHT? WTF?
GO LONG ARM.
CLAYTON IS COOL.
BUT RUBICON IS BETTER.
AND AS FOR THE REAR COIL SWAP. ONLY DO IT IF U R READY TO NOT PUT ANYTHING IN THE BACK. NO LOAD CAPACITY. AND BESIDES LEAF REARS ARE TOUGHER AND WAY EASIER TO FIX ON THE TRAIL.
90xjsweetevil said:thats the plan except ill figure out the tire size after i figure out the lift
TheHighHeat said:I have a buddy with rusty's long arms, Skyjacker 10" coils, and alcan 10" leafs, he runs 37's and it's way to big, but he's planning on running 42's after he trims, only problem is he didn't go full widths so it's really unstable, I'd say get your axles done first so you can tell if the bigger tube size or brackets will give you any lift, then decide on the lift, but decide on tires before you do the axles so you can gear appropriately(which I know that you know all this already)
they make 10" and 12" coils for TJ's88rockxj said:since when does skyjacker make a 10" coil ? i thought the biggest coil out there was rustys 9" coil
robz95xj said:they make 10" and 12" coils for TJ's
im sure the tj coil is a little softer givin you like 1" less lift on a XJ88rockxj said:the biggest they make for an xj is 8" right? or do they have the same spring rates for xj and tjs at skyjacker meaning you can use the tj coils on an xj?
robz95xj said:im sure the tj coil is a little softer givin you like 1" less lift on a XJ
shimmy said:not skycrapper
Jeep-Guy said:I have to ask, why is Skyjacker so bad? Im looking at the 8" kit and I have only heard good things...Why is it bad?
its way overpriced, for less you can get a clayton long arm with a lifetime garenteeJeep-Guy said:I have to ask, why is Skyjacker so bad? Im looking at the 8" kit and I have only heard good things...Why is it bad?
