My engine is running fine, looks very clean inside and has for the majority of its 270k miles run on straight dino oil.....sometimes whatever was on sale at the Pep Boys.RyanM said:Since it got dug up.
RP SL rated, 10w-40. K&N oversized filter. I won't put any of the new SM off the shelf oil's in my rig, or the Group III synthetics. They are niether POA, or PolyEster, nor do they carry the zinc and Ph anymore.edit*(not as much as they should for our cams) (Mobil, Castrol, Penz, Q.S. etc.) I would consider Rotella 15w40 but they have too cut the ZDDP.
I run Delo 400 now because the oil pressure remains steady for long periods on the highway but just as importantly because it comes in a 1 gallon jug.
So I'm curious about the cost/benefit analysis you've done to justify the expense of Royal Purple or any other "premium" oil, synthetic or otherwise? It seems to be an expensive alternative if the oil change interval is not increased to justify the cost.
