What tools are really used for
XJ_ranger
Port Orchard, WA
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets.
ELECTRIC DRILL: Normally used for spinning steel, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VICE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing grease out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for, for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your soft drink across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench at the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouc ...!"
HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after you have installed your new front disk brake set-up, trapping the jack handle firmly under the front fender.
EIGHT-FOOT LONG DOUG FIR 2X4: Used for levering a motorcycle upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting mud off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease build up.
TWO-TON ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your tool box after determining that your battery is dead as a door nail, just as you thought.
TIN SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under motorcycles at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads and can double as oil filter removal wrench by stabbing through stubborn oil filters.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Springfield, and rounds them off.
PRYBAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
XJEEPER said:
Missed one..... "Ignore List"-XJ_ranger: ON
ouch... but - oh wait - you cant see this anyway...
:yelclap: :yelclap: :yelclap: :yelclap: :yelclap: :yelclap:
:rattle:
rock rash said:
:kissyou:
If you guys would quit "quoting" the kiddies most of us have on "Ignore", it would work much better. :gag:
If you don't like the post, you don't have to read it. Hmmm, where have I heard that before?
wha? I thought it was funny.
You are missing the point. Do I need to get Crayons out to point it out to you? :kissyou:
Obviously there is some sort of humor misalignment going on here. I'll get mine checked out right away. Do I need anything more than a tape measure?
A yardstick
Don't forget the laser level
red91inWA said:
What if...... ""YOU" ARE the tool ?
Become one with the TOOL...
oh crap
are they insulting me now?
oh no...
better report this harassment to the BOD via 12 phone calls and 23 e-mails...
:rattle::rattle:
XJ_ranger said:
oh crap
oh no...
:rattle::rattle:
Use the Search Noob. This has been covered before.
1 phone call and 4 emails will work. 12 phone calls and 23 e-mails is borderline stalking. :)
either that or a metod used by "a certain method of the ColoradoChapter"
No, that would be..."A number of emails, PMs and phone calls, none of which I can show here to support my case". Has happened with other points of discussion over the past year...
